I get this r13 also and it is not telling me how much pictures I can take but it comes up when the camera refuses to take any pictures. So tell me please what the problem is.I get this r13 also and it is not telling me how much pictures I can take but it comes up when the camera refuses to take any pictures. So tell me please what the problem is.
You can't post conmments that contain an email address.
I don't have a definite solution however r9 is a heater problem it could be a short curuit between the heater and ground make sure the ground wire has not become loose or corroded
this is not an error code, its the startup sequence to your heater. after those numbers have been displayed you have to press the pool on button and set your temperature
There is no r13 code on your heater. The r13 flashes everytime you turn on your heater, wait, then see if it fires, if not, you will get an error code starting with EO then a number, or the "service system" or "service heater" light will come on.
r 13 is not an error code that is a program that runs at startup when the power is applied then the display goes blank, now you push pool on button and it should work
Try another lens. Make sure the camera is set to AF.
R13 is not an error message - the camera is telling you how many images you can take before the camera has to stop and write to the memory card. Please consult your users manual for further information
Hello Brenden, Did you find the value for r13 on the Mobitronics MPS-50A power supply? I am looking for that value also. I cannot locate where R13 is on the board so if you give me some direction I may be able to help. I do not have a diagram just a power supply that I am trying to repair also. Cheers Stewart Sydney Australia
Rim size 5x13 tyre size 155 R13 78T 5.5 x13 175/70 R13 82H/T 6 x 14 175/65 R14 82H 6 x 14 185/60 R14 82H 6 x 14 185/60 R14 V 6 x 15 195/50 R15 V This Ford recommend to Escort.
The model designation for R13s is not usually on the upper and lower joints. If it was a Prestige, Tosca etc, it might have a little metal plaque on the top joint, but not on a regular R13.
Perhaps you could try a different repair technician - your run of the mill instrument repair person (even the guy who works where you bought it!) may not have the skills needed to really fine tune a professional instrument.
