Question about Polaroid FLM-2632 Television
How do i set the 2632 from cable to uhf/vhf antanna
Posted by wjzcjz on
Chi Chu
  • Polaroid Master
  • 8,457 Answers
Have a good antana like a roof or a HD antana plug into the ANT tv hole.Tv remote push the tv menu.Goto SETUP go down to CH.push and pick AIR not cable.Push for scan for free DTV tv channels.When finish scan u will have all the free DTV channels,depend how good is ur tv antana receptions is.
Posted on Nov 26, 2010
Okay, here I am again, wanting to know how to add cable channels to my Hitachi C21 F800S TV. It currently only shows one channel, BET. Please help! Thanks!
1 Press menu button to enter the menu screens for the following optional adjustable settings.choose
2-tune
3-AUTO SEARCH (Activate to auto search & preset receivable broadcast stations)
-if it don't work change this
4Press menu button to enter the menu screens for the following optional adjustable settings.choose
5-tune
6-BAND (change the band system for tuning (i.e. VHF-L,VHF-H or UHF).
if VHF-L don't work try VHF-H or UHF and restart all over
good luck
Oct 05, 2014 | Televison & Video
Which is better, vhf or uhf
In many business settings you can use either VHF or UHF with success.
VHF: Especially good for people who work somewhat line-of-sight or outdoors. VHF gets around rocks, dirt, hills and trees well and can also be used in many indoor situations.
UHF: While VHF and UHF will both operate line-of-sight up to 2 miles, UHF (450mAH range) gets in and around metal better and even has a better metal punching capability. It also works well in and around concrete structures.
May 01, 2014 | Motorola Radius Vhf Sp21 2 Way Radio...
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Aug 21, 2010 | Televison & Video
I DON'T KNOW HOW TO CHANGE MY TV TO CABLE OPTION RATHER THAN UHF OR VHF
Well let me ask some questions!
1) UHF and VHF are types of off air antenna source signals.
2) Cable TV has both the Analog 'UHF and VHF' signals on them along with the new Digital TV signal sources.
A) Is you TV have a Digital Tuner built into it or are you using a CABLE TV box to hook up to your TV?
Blessings always,
A/V Media Tech Guy
Nov 29, 2009 | Televison & Video
Making the TV VHF plus UHF cable ready
If your tv tuner on vhf only goes to channel 13 you will not recieve uhf channels if you are hooked to cable tv. You can do a search for mid band to uhf converters (converts uhf to vhf).We used to use them in the early 80's. Even if you can find one it will only go to channel 22.
Jan 27, 2009 | Curtis RT700 7 in. Portable Television
No uhf with antannae
UHF channels are basically "line of sight" type signals. You need to be pretty near those UHF stations.
You need a Uhf or combination Uhf/ Vhf antenna to receive them - - Usually an out-door type.
Your TV needs to be set in the "antenna" mode to tune beyond channel 13 "air type" channels. Channel 14 is the first UHF channel if you're in the antenna mode. If you're in the "Cable" mode then channel 14 is a cable channel which is operating at a different frequency from UHF.
I hope this will help you!
Stargazer
Mar 21, 2008 | Orion STV2763 27" TV
No cable
try going into the menu of the tv and changing the tuner type from ANT to Cable
Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Setup will not connect to uhf stations using rabbit ears antenna1
Signal is not strong enough. Use outdoor aerial for best results.
Aug 21, 2017 | Sharp 27U-F510 27" TV
Reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Sep 01, 2007 | Televison & Video
Polaroid FLM-2632 Television Logo
130 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
