Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
It will turn itself off and when i try to turn it back on the led light flashes green orange then red and wont come on if i unplug it for a little bit sometimes it will come back on but the problem keeps getting worse
Posted by turbofelon on
Chi Chu
  • Sony Master
  • 8,457 Answers
The "LAMP" LED light indication flashes or staying on too?Yes,than the lamp life are over.Require a new lamp for the replacement.
Posted on Nov 26, 2010
My Ac Adapter i think is broken and my Xbox wont turn on but the AC adapter has a orange light that when i unplug it the orange light still does not go off.
Hi if the main brick has got an orange light then this is telling you the mains lead is working so try doing the following
1 unplug all leads from back of xbox and turn the power brick off at mains
2 plug the power lead back into the xbox, now when you push it in and it stops try pushing it in a little bit further usually they just dont push in far enough and it can be quite tight so make sure you are pushing it in hard enough,
3 now plug the video lead in and try switching it on,
keep an eye on the orange light whilst you switch it on if it comes on then it should continue to work if it dont come on watch the orange light and see it if changes color at the same time your switching it on, it will either flash green or red just once before going back to orange.
let me know what happens ok
Nov 28, 2010 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Canon IP4300 flashes orange and green
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Oct 25, 2009 | Canon BubbleJet i560 InkJet Printer
TV wont turn on
The main power supply is failing or it is shutting down because of a fault on the output side of it and it is trying to protect itself from overload which can cause a fire. Contact Zenith customer service and describe the problem, particularly the flashing LED which may be giving you an error code.
Sep 04, 2009 | Zenith E44W46LCD 44" Rear Projection...
When i plug in my usb charger, the light flashes red green then orange. even without my battrie
try cleaning the battery(copper bits) try charging it on your lap top, it should flash red green orange, keep unplugging and plug back in again its worked for us
Jun 24, 2009 | Samsung NV3 Digital Camera
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Canon ip5300 b200 error message unplugged and replugged lights still flashing between green and orange pulled all printer cartridges no resolve
Jun 16, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
Samsung SPN4235 42" Plasma
green light flashing no video but audio, on/off switch in operable
Nov 12, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Tv will not turn on--- flashing red led
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
Jul 11, 2007 | Philips 37FD9954 37 in. HD-Ready Plasma...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
71 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
