As long as the heater is still working good and not leaking I would just replace the Temperature and pressure relief valve. To do this turn control knob on gas valve from on to pilot. This will maintain pilot so you won't have to relight later while keeping the burner from firing while you are replaceing t&p valve. Turn off water supply on cold water supply to water heater.If this valve won't work or you don't have one shut off supply to house. Do not attempt to remove t&p valve until you are sure water is off. Open hot water on faucet close to heater and drain a few gallons from water heater drain valve. Purchase new t&p valve at hardware store. They are pretty standard 3/4 inch male pipe thread, 150 p.s.i. rated. Use teflon tape to seal pipe threads ,4-5 wraps at least or pipe joint compound to seal threads You will need a pipe wrench to remove old valve. Turn it counterclockwise to lossen then remove. Have new valve ready to go to minimize water loss. Be carefule as water will still be hot. Install new valve and tighten securly. Turn water back on and check for leaks. Also shut off faucet you opened. Once you are satisfied there are no leaks turn gas valve to on and bleed air from several places. I hope this helps you. Thanks.
