SOURCE: I have replaced the temperature sensor (black ring
Did you bleed the coolant system after the install?
Normally it is just to start the engine and let it cool down,Then remove the switch again and fill the coolant from that hole.
Do you get constant heat from the system?Or do you get warm then hot air.If so it is a bleeding issue.
SOURCE: Omnitech Wireless Weather Station model
Push and hold down the channel button, wait for beep, then on the sensor, push and hold the tx button, wait for beep.
SOURCE: My weather station by Lacross will not display the
http://www.lacrossetechnology.com/9611/manual.pdf
If that's not the right manual,you can use the link below, and select the model..If the model is not there, that means the manual is not available...
http://www.lacrossetechnology.com/support/manuals.php
Take care
CODE 15
Trouble Code 15 indicates that the Coolant Temperature Sensor (CTS) is reporting abnormally low readings. CTS is used to control fuel mixture, timing, idle speed, TCC and EGR operation, among others. The thermistor used has a high-resistance when cold, lowering as the coolant warms.
Code 15 will set if:
- temperature reported is < -37.30 deg F (-38.5 deg C)
Typical causes may include:
1. Open circuit in CTS-ECM harness
2. Defective Coolant Temperature Sensor
3. Open sensor ground circuit
4. Defective ECM
