Sounds like an excessive lint build up somewhere in the exhuast line. The first obvious thing to do is clean out your lint trap. Then remove the exhuast line from the back of your unit and make sure it is thoroughly cleaned out. You should also check the outlet where it exits the dwelling, some of these vent louvers get plugged right there.
Could be condenser or water solonoid valve fact that s hot says heater ok.fact that its wet perhaps not cooling down to water and pumping out fully, also check that the filter is clean....
