GE JTP15 Electric Single Oven Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm trying to use the self clean feature on the oven., After a short cycle- I get a F9 on the temperature control and the oven stops cleaning. What is wrong?
espressonist
Level 3:
  • GE Master 1,711 Answers
  • Posted on Nov 26, 2010
espressonist
GE Master
Level 3:
Answers
1711
Questions
Helped
651816
Points
5029
The F9 means Lock switch. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. You can check for loose or overheated wire connection.
Why does it say "Clean Door" during the self-cleaning procedure?
Never ever use the Self Clean feature. All it exists to do is to keep the makers in a steady stream of sales of spares. The temperature is 800 to 925'F. The parts can't handle it.
Try turning off at the breaker overnight to reset.
Why You should Never Run A Self Clean Oven Cycle & A ...
General Appliance Service https://www.generalappliancesvc.com > why-you-should...
Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipedia https://en.wikipedia.org > wiki > Self-cleaning_oven A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ...
Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cleani...
Feb 2, 2024 - Auto-cleaning, also known as "pyrolytic cleaning," operates by heating the interior of the oven up to 500?C. During this process, grease is ...
How Self-Cleaning Ovens Work · ‎Major Parts Damage
Feb 26, 2024 • GE Ovens
1helpful
I have an older Roper by Whirlpool self cleaning oven. It does not have a door lock or timer. Do I just close the door and turn the oven to clean and it will indicate when the cycle is done?
Never ever use the features of a Self Cleaning Oven. We see the damage they do here on Fixya, and the worst is the door not unlocking, and the most expensive is when they fry the mainboard.
They all have a door interlock. If you were to open it when it was running, it would frizz your eyebrows!
Why You should Never Run A Self Clean Oven Cycle & ...
General Appliance Service https://www.generalappliancesvc.com > why-you-shou...
Self-cleaning oven
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cle...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to aid in ...
Big white spot in the oven, who disappears when wet
Ah, well that's you problem, Number 1 Tip, never EVER use the Self Cleaning Cycle. So many questions here on Fixya are because the self cleaning cycles has caused broken door catches, and even fried control boards. The whole idea of this gimmick is to sell spares and keep service agents in business when they break . The temperature of approximately 932 °F (500 °C) is just too hostile.
https://www.generalappliancesvc.com > why-you-shoul...
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) ...
https://fixappliances.ca > 4-reasons-stop-using-self-clea...
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters at an extremely high temperature (932 F° or 500 C°) to ...
How Self-Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Feb 24, 2023 • Ovens
Oven door remains locked after self clean cycle - but the oven has cooled
Number one Tip, NEVER use self cleaning cycles. They only exist to break ovens and sell parts.
Try disconnecting the mains after about 10 minutes of cool down time. If that doesn't work, you will need a service call to correctly diagnose if the lock solenoid has failed or you need a new control board.
Why You Should (Almost) Never Use Your Oven's Self ...
https://www.thekitchn.com > why-you-should-almost-n...
Sep 8, 2022 - Self-cleaning, often with temperatures that go over 1000°, is a particular problem. The elements and the oven just get so hot - much, ...
4 Reasons to Stop Using Self-Cleaning Oven Feature ...
Jan 31, 2023 • GE Ovens
No heat on convection or self clean
If you have been using the self clean feature, you have probably burned out or damaged the connections to the fan and the convection fan element or thermistor. NEVER EVER use the self clean feature.
https://www.partselect.ca/Models/CGEB27S7CS2/Sections/BODY/?ModelID=1073773&ModelNum=CGEB27S7CS2&mfgModelNum=&ManufactureID=4&Selected=OTRVH5GS&Position=1&mfg=Frigidaire&Type=Wall%20Oven&Mark=1
A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or 500 C°) to ...
How Self Cleaning Ovens Work · ‎Major Parts Damage · ‎Family Safety
Jan 29, 2020 - With an inside temperature exceeding 500° C, and a flash point (the temperature at which items can self-combust without an ignition source) .....
Electrolux oven door won't open
Were you using the dreaded 'Self Cleaning' cycle?
Number one tip, never ever use the self cleaning cycle. The oven locks, wiring and sometimes even the hob wiring can't cope with 1,200'F.
Call for service.
2answers
Frigidaire GLEF378ASE range oven cuts off during self cleaning mode.
My advice is never to use the self cleaning feature. Each time you use it you are a little closer to breaking something, elements, fans, door latches and one poor man who had a burned / melted control board which was obsolete so he had to purchase a new range. We see it here all the time. It is a great way to sell spare parts. 800 to 1000'F is just too severe for the parts.
Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 ...
1helpful
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 • Ovens
Try to use selfcleaning feature on range and as soon as door locks it stops and goes to F9
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
