Question about Kenmore 96532 / 96534 / 96539 Electric Kitchen Range
I have a Kenmore Range that stopped working in the middle of cooking my Thanksgiving Turkey. Upon discovery the power was off because it flipped the circuit breaker. When we reset the circuit breaker it started beeping with a code of F-1 and the door locked. Turkey inside. After flipping the circuit breakers several times the door finally unlocked but the stove does not work. The range top will work but it beeps constantly and F-1 is displayed in the screen. Is this fixable?
5 Suggested Answers
Anonymous
SOURCE: Kenmore electric range
You need a new mother-board.
I had the same issue, it overheated my kitchen in a matter of minutes. If I didn't turn off the circuit-breaker, I probably would have had a fire - the heat being emitted was intense. The cost is running around $300. with tax and delivery. I'm not sure if I want to repair or purchase a new oven.
Posted on Sep 25, 2008
Anonymous
  • 360 Answers
SOURCE: my kenmore kitchen range has
First you will need to check for proper voltage at the plug (behind the range) ensure you have 120/240 volt available.
F1 generally indicates a control board fault/failure. If you have attempted to reset the unit by unplugging it for about a min. or more and plugging it back in and the F1 error code returns, you will most likely need to replace the EOC (electronic oven control) board. Parts for your unit are available through Sears or other aftermarket parts suppliers.
Please take the time to rate this solution
Posted on Jan 29, 2009
Anonymous
  • 8 Answers
SOURCE: The breaker tripped when I turned the oven on.
Sounds like the Oven temperature probe has failed.
Posted on Jul 03, 2009
Bruce Hathcock
  • 3600 Answers
SOURCE: Am making my Thanksgiving dinner today. The oven
one of the burners is blown turn breaker off and remove top heater element then turn on breaker, does it stay on? if yes you found your problem burned out element that is shorting. pull one at a time till it stops resetting the breaker, be aware resetting the breaker more than 10 times considers they breaker not reliable but have personally not have had a problem unless it was 20 years or older.
Posted on Nov 28, 2009
shawna2
SOURCE: I have an error message and cannot get it to
I have the same problem, if you figure it out please post it.
Posted on Sep 06, 2010
I have a 30 qt pot, cooking a 18 lb turkey. placed turkey in pot and added water. amount required is above maximum limit level. Can I exceed?
If you are frying it, no you can't. As moisture comes out of the turkey, it will cause the fat to boil over.
You say you 'added water'. You are making boiled turkey for Thanksgiving? You could, but not the same.
I have two suggestions.
Cook traditionally in the oven. I am a chef and have cooked my turkeys breas t side down for a bout 20 years. The result is a much moister breas t on the turkey.
or
Split the turkey and deep fry in two batches.
The word breas t is considered as profanity on Fixya. Please review your answer and try again.
Nov 25, 2015 | Bayou Classic Kitchen Appliances - Others
The label on my frozen turkey says it is good till March of 2016 does this mean even if its thawed it will still be good till that date?
Hi Ronnie:
- If it has been sitting unfrozen in your fridge for more than 2 days I'd personally not be eating it.
- Likewise, if you cook it, it should be eaten right away.
- Re-freezing uncooked is not considered safe food protocol.
- Freezing cooked in serving size portions and only thawing when you're going to heat and eat is usually safe.
Hope this helps.
Nov 14, 2015 | Toys
Frigidaire electric stove does not work at all
First check the breakers at your house's breaker box. A tripped breaker will be a little bit away from on. Push it all the way off, and then back on. If it trips again, call an electrician.
Dec 01, 2013 | Frigidaire Gallery FGEF3055M 30"...
Gas oven on Kenmore range model 362-75191890 went off midway through roasting Thanksgiving turkey. There seems to be no gas getting to the oven burner, even though the range top burners fire up nicely.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Kenmore Kitchen Ranges
When using the convection roast, does setting it to 325 show on the display as 300? I am cooking my turkey at 325 and display reads 300.
Your range has the feature called auto recipe conversion,that means it will automatically adjust your settings to compensate for the changes when useing either convection modes, bake or roast,rest assured you turkey will turn out perfect with convection roast. Remember that raosting time will be slightly reduced also with convection roast bakeing. Have a wonderfull Thanksgiving and Holiday season. Good luck !
Nov 26, 2009 | LG 30 in Kitchen Series Dual Convection...
Convection oven quit working half way through cooking thanksgiving stuffing
Call us right away with your brand and model number and we'll get the correct part out to you right away in time for Thanksgiving turkey!! We look forward to
working with you.
Oct 18, 2009 | Ovens
Breaker flipped on my oven while cooking a turkey
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
May 16, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidiare electric range time bake and self cleaning
F3 The oven temperature sensor is open Check for open wire connection between EOC (Electronic Oven Control - Clock) and the oven temperature sensor. Replace sensor if no wiring problem. F3 Oven temperature sensor open Check oven temperature sensor, 1100 ohms F3 Oven temperature sensor open Replace oven temperature sensor F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control
Nov 26, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore 96532 / 96534 / 96539 Electric Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
