HP Photosmart C6180 All-In-One InkJet Printer Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink system failed???unable to print,copy,recieve faxes
Michel Smith
Level 3:
  • Master 1,218 Answers
  • Posted on Nov 26, 2010
Michel Smith
Master
Level 3:
Answers
1218
Questions
Helped
795100
Points
2925
Hello
Have a look at the link below, it should assist you in solving your problem.
http://h30434.www3.hp.com/t5/Other-printing-questions/Ink-system-failed-Error-Oxc18a0101-on-photosmart-D7160/m-p/14911
I'm getting a message: Ink System has failed. Unable to copy, receive a fax, or print. Refer to printer documentation Error 0xc05c0381 Turn power off then on again
throw the *********** off niagra falls! Oh,one more chance to solve the problem? tell me! This copier was set up for 90 days to recieve faxes of which it may have recieved 10 test faxes then 2 or 3 real faxes then "ink system failure" 0xc18a0006. This cannot be difficult! As a technition for 40 years,a module swap would seem to resolve any problem. This is not right or fair. I have dozens of pc systems RFU. This one sat idle awaiting a lonesome fax and died without so much as breaking a sweat. No,a chicken did not **** in it! When my Moen faucet has problems,one call to Moen gets me a free overnight fix without a hassle. Why can't HP do as well? Doc Lowe, 512-422-6434; [email protected]; fax512-328-8793.........
2helpful
Ink system has failed. Unable to copy, receive
normally in this scenario the whole printer needs to be replaced..
1helpful
Printer won't print
Try this Issue When trying to copy, print, or receive a fax, the following error message appears on the product control panel display. Ink System Failure. Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc19aYYYY NOTE: The Y in the error message represents any digit, 0 - 9, or any character, A - F. Solution To resolve the issue, use the following steps. Step one: Remove the cartridges Make sure that the product is turned on and then disconnect the USB cable from the back of the product. Open the product cover and remove the cartridges. Close the cover and wait for a message to insert the cartridges to appear on the control panel display. Disconnect the power cord from the back of the product. Disconnect the power cord from the wall outlet and wait for one minute. Step two: Reinstall the cartridges Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on. Open the product cover and reinstall the cartridges. Close the cover and print a calibration page, if prompted. Print a self test report to make sure that the product can print. Reconnect the USB cable between the product and the computer. Try to print a document from an application on the computer.
2answers
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
9helpful
2answers
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
1helpful
4answers
Solution
Wait two minutes.
k24674
Grand Canyon Tech
Grand Canyon Tech
