Question about Fuji FinePix J10 Digital Camera
How can i download pictures from my camera using the memory card
Posted by nirahforever on
AliTech110
    Brigadier General:
  • 7,191 Answers
You can download pictures from your camera to your computer by using a memory card reader. (You can use your computer's built-in memory card reader, if it has one, or you can purchase an external memory card reader as shown in the attached image).
To do this, kindly remove the memory card from the camera and insert it into a card reader. Connect the card reader to the USB port of your PC (if you are using an external card reader).
Now, the memory card will be shown as a "Removable disk" in "My Computer". You can browse the images and download the pictures to your computer.
Hope this solves your problem. Thanks for using FixYa.
Posted on Nov 26, 2010
I have pictures on my camera hard drive the I can't get off
Two ways:
  1. Use the "Copy" command in the playback menu to copy the pictures from the internal memory to the memory card, then download the pictures the same way you normally download from the card.
  2. Remove the memory card before using the USB connection to connect to your computer, then download the pictures from the camera.
You may download a copy of the manual here.
Jul 30, 2012 | Fuji Finepix J50 Digital Camera
I dont know how to transfer my pictures from my sp-600uz into my pc. could you help me please? thanks
Hello and welcome to FixYa
To upload your photos from your camera
Olympus SP600UZ Digital Camera to PC
1.First connect your digital camera to your computer.
You can do this in two different ways:
Use a USB cable:Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer.
Through memory card:A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk.
Now connect USB cabe or Memory card Reader to the port of the computer
2.Once you've connected your camera to your computer or inserted your memory card into your memory card reader, your computer will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK
If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK.
3.When the Scanner and Camera Wizard appears, click Next.
4.All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next.
5.On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures.
6.
If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card.
7.On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next.
8.On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera.
Your photos are now stored on your PC, ready for whatever you want to do with them, and your camera is ready to take more pictures.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
IF IT HELPS YOU then Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
Thank you for using FixYa!
Apr 20, 2011 | Olympus SP600UZ Digital Camera
I am trying to download pics from my Canon G11 to my computer and have it plugged in but don't know what to do next.
Canon PowerShot G11 Digital Camera to computer
6.
Your photos are now stored on your computer, ready for whatever you want to do with them, and your camera is ready to take more pictures.
I hope this will surely help you. Further assistance i am here to help
If you think it was helpful for you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Apr 01, 2011 | Canon PowerShot G11 Digital Camera with...
COMMUNICATION ERROR: Trying to download my 3,500 pictures from my
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 30, 2010 | Canon PowerShot SX120 IS Digital Camera
How do i get the pictures from my camera to the memory card
the question I ask is why would you want to do this?
The camera has XX Mb of memory in case the card becomes full. Generally one downloads the pics on to a PC and deletes the Camera files to start again
If you want to keep the pic files in memory and save them tpo your pc. remove the card for safety.. Interrogate your camera via the connection cord and the software it came with. Download the folder with the pics in memory to your PC. Then delete the files on the camera. Insert the SD card and In menu, set up to save files to SD card rather than memory while there is space.
Please rate my help++++Thanks fore using FIXYA
Apr 16, 2010 | Samsung L200 Digital Camera
I want to download my photo's from camera to hp laptop
After you take pictures with your digital camera, you'll want to copy the pictures from your camera to your computer so you can print them, share them with others, and back them up for safe keeping. Once your pictures are on your computer, you can erase them from your camera, freeing up memory so you can take more pictures. You can also view your pictures on a larger screen and decide which ones are worth keeping. Some digital cameras come with software that helps you copy pictures from your camera to your computer. You can use this software, but you don't have to. Windows XP can copy pictures to your computer without requiring additional software. Here's how to copy your pictures using Windows XP: 1. First connect your digital camera to your computer. You can do this in two different ways: ?Use a USB cable. Most digital cameras come with a cable that connects the camera to a USB (Universal Serial Bus) port on your computer. ?Use a memory card and memory card reader. A memory card reader is a piece of hardware that plugs right into your computer. You remove the memory card from your camera and insert it into your memory card reader, similar to the way you might transfer a file between two computers using a floppy disk. Tip: It's usually faster to use a memory card reader to copy your pictures than to connect your camera to your computer with a cable. 2. Once you've connected your camera to your computer or inserted your memory card into your memory card reader, Windows XP will detect the connection and ask you what you want to do with your pictures. If you connected your camera with a USB cable, click Microsoft Scanner and Camera Wizard, and then click OK. If you are using a memory card reader, click Copy pictures to a folder on my computer using Microsoft Scanner and Camera Wizard, and then click OK. 3. When the Scanner and Camera Wizard appears, click Next. 4. All of the pictures on your camera (or in your camera's memory card) are now displayed on the Choose Pictures to Copy page. By default, Windows XP selects all of the pictures for downloading. If there are pictures you do not want to download, just clear the check box next to those pictures. At this stage, you can also rotate pictures that you took while holding your camera vertically. To rotate a picture, click it, and then click either the Rotate clockwise or Rotate counterclockwise button on the lower-left side of the page. When you have reviewed the pictures for downloading and rotated your vertical pictures, click Next. 5. On the Picture Name and Destination page, type a name for the group of pictures. (This name, plus a number to differentiate each picture, will be applied to each of the pictures you download; for example, if you name the group "Vacation," the pictures will be named "Vacation001," "Vacation002," and so on.) Click Browse, and select a folder in which to save your pictures. Tip: Create a new folder for each group of pictures you download. 6. If you want to erase the images from your camera's memory card to make space for new ones, select the Delete pictures from my device after copying them check box, and then click Next. The Scanner and Camera Wizard copies the pictures from your camera to the folder you specified and then removes the pictures from your camera's memory card. 7. On the Other Options page, you can choose to publish your pictures to a Web site or order prints. If you have finished working with your pictures, click Nothing, and then click Next. 8. On the final page of the wizard, click Finish. Windows XP opens a Windows Explorer window showing the pictures you downloaded from your camera. Your camera's memory card is now clean and ready to store new pictures. If you connected your camera to your computer using a USB cable, disconnect your camera. If you used a memory card reader, return the memory card to the camera. Your photos are now stored on your computer, ready for whatever you want to do with them, and your camera is ready to take more pictures. As with any important files, it's a good idea to make backup copies of your photos, in case anything happens to your computer
Apr 08, 2010 | HP Photosmart M547 Digital Camera
I have about 20 picture on my camera that is on my camera memory and not on my memory card. How can I download these pictures to my computer to get them off my camera?
You have two options.
1) From the Setup menu choose the Copy option and use it to copy pictures from the internal memory to the memory card. Once done you can download the pictures from the memory card as usual.
2) Remove the memory card, if any, and then connect the camera to the computer using the supplied USB cable. You can then download the pictures from there.
Jan 21, 2010 | Nikon COOLPIX L100 Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Downloading pictures from memory card
Not sure if this will help, but after I used a reader/writer, I could no longer see the pics that were on my memory card unless I had it in the camera. A reader/writer reformats, so you will need to reformat the memory card to upload to your pc.
Oct 22, 2007 | Kodak EasyShare Z710 Digital Camera
Fuji FinePix J10 Digital Camera Logo
119 people viewed this question
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
