Question about Boston Acoustics PV1000 Subwoofer
I have a Boston Acoustics PV1000 that's getting no power but the fuse appears to be OK. What else could it be? thanks
Posted by gabedelfabbr on
Anonymous
    New Friend:
  • 7 Answers
I have the same problem. La Mars covers the factory repair for these. Their number is 712-546-1644. Have you fixed your problem yet ?
Mark
Posted on Dec 28, 2010
Boston micro 95pv sub-woofer is blowing 3A Slow Blow fuses.
I would expect a shorted component in the power supply
Sep 06, 2016 | Boston Acoustics Micro90X Speaker
Boston Acoustics Recepter Radio HD stopped working - no power. The power supply is fine. is there a fuse in the radio?
There should be a fuse in the back but it would only blow if the wiring is funny because the car's fuses are closer to the power supply and should go first, but try anyway
Apr 24, 2014 | Boston Acoustics Recepter Radio(r) HD
Boston acoustics pv-1000 won't power on
Just fixed my PV1000 that would not power on. Verified 185vdc on bulk capacitors. Measured 11vdc on U5 (UC3842) from pin 5 (gnd) to pin 7 (vcc). Then measured 0vdc from pin 5 (gnd) to pin 8 (ref). This should be 5vdc. This means that U5 is shut down for undervoltage. Turned out to be two open resistors. R94 100k 2w and R77 33k 2w. Never would have guessed that as there was no sign of heat discoloration. They are next to each other between U5 the UC3842 PWM IC and Q3. This prevented the proper startup voltage for U5. Replaced them and I'm off and running once again. Hope this helps someone.
Oct 27, 2013 | Boston Acoustics PV1000 Subwoofer
My PV1000 does power up when plugged in. Can you send the wiring schematic and troubleshooting guide.
Hi David,
First of all, thank you for posting your question here at Fixya.
May you please email me at [email protected], I will send you the copy.
Again, thank you so much!
Rating and feedback are highly appreciated.
Mjsazon
Jan 12, 2012 | Boston Acoustics PV1000 Subwoofer
Drivers Boston acoustics
Looking up these speakers, it appears that they connect via a 3.5mm headphone jack. This type of interface does not require a hardware driver. Instead you need the driver for your sound card, download the driver from the website hosted by the manufacturer of your computer.
please rate my solution
Jul 21, 2010 | Boston Acoustics BA265 Computer Speakers
The amplifier module in my Boston Acoustic PV1000 Subwoofer has fried itself. According to the New Zealand importer, a new module is not available. Any ideas? Would there be a wiring diagram avail? Maybe I...
Here is information from the factory repair company for this product.
For repairs that are out of warranty: The Boston Acoustics PV1000 has a $130 flat fee that covers parts and labor regardless of the problems you are having with the unit. Return shipping is figured (with your zip code) at the time of return and added to that fee.
When packaging the unit please include a detailed problem description and
full contact information (name, address, phone). For this particular model you can send in just the amplifier pcb, and keep the cabinet in your possession, (to save immensely on shipping)
Upon arrival here at LAS, your name first and last will become the RA and
future communication will be referenced by that name.
We will contact you for payment of $130 +return shipping. We accept Visa and Mastercard over the phone, or check or money order via mail. Turn around time is generally 3-5 days
after receipt of the unit.
If you have any questions or uncertainties don't hesitate to call the number below or respond to this email.
The address for return is:
LeMars Audio Service
1889 24th St SW
LeMars, IA 51031
712-546-1644 opt2
Nov 14, 2009 | Boston Acoustics PV1000 Subwoofer
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
Speakers
The Boston Acoustics power supply that came with Model 7000596 speakers is rated:
Input 120VAC 60HZ 23VA
Output 12VAC 1500mA (1.5A)
The PS model number is WK1201A5-1AN
Dec 28, 2008 | Boston Acoustics MicroMedia Computer...
Boston acoustic BA735 speaker problem
Dear oneeyemike77
I am sure that it is not due to one line around. Just check weather the power is on and also check the sound settings on ur pc, it may have been muted or the sound level must have been reduced. You can also check your speakers by connecting it to a mini player or a mp3 player. Dont worry pal, this will surely get u working....!!! Please rate me.
Thankyou
Feb 10, 2008 | Boston Acoustics MicroMedia Computer...
Boston Acoustics PV1000 Subwoofer Logo
578 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
