Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on.
Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
will hear a third beep and the system will power off (power light is
red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on.
Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset.
Continue to hold the power button and after about another 5 seconds
you will hear a quick double beep. At this point release the power
button. if you succeeded in activating the safe mode, you will see a
message on the screen saying 'connect the controller using a USB cable
and then press the PS button.
Step 4 - Perform the safe mode options in the following order until
one of the options works for you. If one option works, do not continue
onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Cheers
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
We have reviewed each problem and given you a link to the
best solution below:
Hope this helps?
