Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Hi, I have a robbin 34134z indicates high pressure and do not work. At times it works and then stops working. I can do? . I live in Venezuela and here there is no Robinair agent indicated as repair them. I think it's a calibration error. Thanks for your help
Posted by alfredotroco on
Hasan Khan Amran
    President:
  • 181 Answers
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# May the ISV tank is not overfilled,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Posted on Nov 26, 2010
  • Hasan Khan Amran
    Hasan Khan Amran Nov 26, 2010
  • Hasan Khan Amran
    1# May the ISV tank IS OVERFILLED,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid for proper operation.Hope this will solve your problem, Best of luck
Why my 34134z dosent want to charge? I all ready change the compressor
Did you evacuate the system for the proper amount of time? There are pressure switches in the system that you may have to bypass so the clutch will engage.
Nov 19, 2014 | Cars & Trucks
My freezer was running a lot I guess the over load tripand stop working.replaced overload and relay and my gauges indicate high back pressure any ideas how to fix it
High back pressure is generally a sign that the evaporator coil is clogged with debries or the fan isn't working I suggest checking this first.
Oct 11, 2013 | Silver King 1242.90 Front Breathing...
My house air conditioner will blow cold air for a while when it is really hot outside ( i live in the california desert area ) but nothing but warm air will come out after the ac has been working for a...
Hi and welcome to FixYa, I am Kelly,
This certainly sounds like a low system coolant level issue. Have someone check the system pressures. Low side should usually be 65 to 70 unit running. High side will vary with outside temps any where from 135 - 170. If you do not have good low side pressures it will affect the high side pressures also. This is really the only way your going to sort this one out.
Look around the evaporator and the condenser for any signs of OIL or dark spots caused by oil. That is usually an indication of a system coolant leak.
Thanks for choosing FixYa,
Kelly
This is who answered your question:
http://blog.fixya.com/index.php/2010/05/award-winning-service
Jul 10, 2011 | Heating & Cooling
Lavor Super wash Powerwasher.Lidl. Pressure leak O ring replaced at Venturi & wrote down wiring diagram for On/Off switch as follows- Blue Red Brown, Black. Had to disconnect wiring from On/Off...
hi i have a lavor 160 superwash all off the lances work except when i put the turbo lance on it gives high pressure and then goes to low pressure like starting then stopping can anyone help me or tell me what the problem may be
Feb 28, 2011 | Kitchen Ranges
HI, I HAVE A ROBINNAIR 34134Z AC UNIT. I AM NOT ABLE TO ADD 134 TO SYSTEM PUSHING KEY PAD ARROW UP. POUNDS REMAIN AT 0.0. ON ALL OTHER FUNCTIONS, KEY PAD WORKS FINE.( UP--DOWN). REMOVED COVER, REMOVED AND...
Please try the following: 1# Verify the ISV (tank) dose not have excessive pressure.note the tank's temperature & pressure readings and compare to pressure chart on unit.purge excess air if necessary.the refrigerant may be contaminated and should be handled appropriately.
2# Press recover & verify the Recovery solenoid (S1) is receiving power & opening properly.
If not receiving power check continuity of the wiring between solenoid & circuit board,repair as needed.
If the wiring is correct and no power is being applied to the solenoid,replace the circuit board.hope this will help you.
Jan 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
Cannot find flasher unit 4 ways work nornal
asked aa man also if four ways work and flashers dont its a fuse box is at side of accelarator under dash on 2001 model
Dec 07, 2009 | 2001 Suzuki Vitara
AC stops working when cabin temp reaches 109-110
indicates gas pressure and condenser cooling problems
check the condenser fan is working properly and have the gas pressures checked by gauges
check that the evaporator fins are clean and not blocked as ice build up will cause the same indications
Apr 07, 2017 | 1997 Audi A6
Freezer not working but motor working
hi! that symptom correspond hizzing sound on evaporator.factors are to be check before you can diagnose insusfficent cooling effect check your actual opearating current using clamp ammeter,set to amperes rating,clamp to one line source take thereading,compare reading on the tag locate at the backside of freezer there is rated ampers indicated.if you got low amper rating your system is under charge,thats the time you recharge your system by qualified ref/ac technician.but if you got high amper rating your filter need to replace as well as your refrigerant.check also the high side pressure by service pressure gauge manifold or the compressor discharge pressure if can compress to 300 to 500 psig.if not your compressor has loose compression.compressor is worn out.
Mar 17, 2009 | Kenmore 61042 Top Freezer Refrigerator
Cooks essentials pressure cookr not going on the high setting...
If the unit is not together and locked the high pressure setting will not work! make sure its locked and put together before you set it!
if this still does not work you may have a faulty switch!
Jan 24, 2009 | Cook's Essentials Cooks Essentials Arome...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
1,757 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Hasan Khan Amran
Hasan Khan Amran
Sheldon Dedek
Mike
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
