Dacor ECS127 Epicure Electric Single Oven Logo
Question about Dacor ECS127 Epicure Electric Single Oven
What does "PRB 400 (degrees)"
Posted by achen61255 on
Anonymous
  • 10,515 Answers
PRB stands for Power relay board.
This is a bad error. This means that the power supply board had failed and needs replacement. The cost of replacement would be anywhere between $150 to $300.Unfortunately, this is not a DIY. You need to call a tech on site to replace the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 26, 2010
My Dacor oven keeps beeping and flashing PRB. How do I stop the beeping?
Most unwanted beeping on Dacor products are due to a bad touchpad... Use your model # and start looking for a replacement , by touchpad I mean a part something like this one: Dacor Touchpad 62678B
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 • Ovens
My probe (PRB) keeps flashing and beeping, how do I make it stop? Thanks!
Hello, Thank You for using FixYa. I will be helping you today.I just had a service call on this issue. If the probe receptacle is clean you may have to replace the control. Try turning off the power for five minutes and see if that works.
Thank You and please rate my answer if it was helpful..
Error code -fc- beeping will not stop?
From JENN AIR FAULT CODES...
FC - Communication error between boards - Wiring harness or power relay board (PRB)
Hope helps.
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
My "Probe" keeps beeping. I tried cancelling...no help. Tried heating oven at 400 degrees as suggested by one person (to take out the humidity....)for 15 mins. Helps for awhile but then starts beeping...
The top oven the stove will lift up,with effort,and fold back,unplug first,and see if it needs cleaning and the sensors are in there I think,clean them,try to unplug it to reset,see if that helps.
4helpful
3answers
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 • GE Ovens
3helpful
Oven constantly beeping
PRB refers to the power relay board.It is not an error message.Probably the PRB is damaged and needs a replacement.All the best.And please do comment as to how else i can help you.
Jan 15, 2009 • Ovens
2helpful
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Top Dacor Ovens Experts
Jaime Hernandez
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
