Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
I have a cisco router E1000. I want to connect a wifi radio to wireless. It is asking for wpa password. How do I find password? Should I reset? If so what are default password and username? Earl
Posted by eonlee on
5 Related Answers
Anonymous
  • 89 Answers
SOURCE: Default username for 5461 maxg
Hello, The easiest way to correct it to reset router back to default. Reset hole/button on back need to be held in 10-15 seconds. 5 seconds or less and it will reboot router. Once it is reset to default use 192.168.1.1 for address and "admin" for password. Leave usename blank. After in settings these can be changed. Hope this helps.
Posted on Mar 27, 2008
imp_squared
Joe L.
  • 56 Answers
SOURCE: Broadband Router is asking for username and password
If you haven't setup a username and password on this router before.
Then it's probably using the factory default username and password, for that visit the manufacturer's website.
If you have setup a username and password before on this router, but forgotten what the password is. Give the router a hard reset. How to do that can be found in the manual.
Posted on Aug 14, 2008
techjuli
Juli H.
  • 157 Answers
SOURCE: cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
Posted on Nov 30, 2008
Anonymous
  • 79 Answers
SOURCE: password reset of cisco 2800 router
Straight from Cisco:
Password Recovery Procedure for the Cisco 2600 and 2800 Series ...
Posted on Jun 11, 2009
Anonymous
  • 392 Answers
SOURCE: default username and password
username :- cusadmin password: - password
this is the default password, this is for the version 2A , port or protocol = http://192.168.0.1
i think this solves ur issue.
Posted on Jun 22, 2009
Linskys e1000 reset and password
Hello from here you can download a manual:
http://homesupport.cisco.com/en-us/support/routers/E1000
You need to install Cisco Connect software.
To reset it you have to press a small button at the back of the router
With power on.
E1000 Default Password & Other Default Login Data Version Default Username Default Password Default IP Privileges All [none] admin 192.168.1.1 Administrator
Good luck
Oct 29, 2012 | Cisco Linksys Wireless N Home Router...
Need username & password for my E1000
First check the wireless settings of your router. You will find all the wireless settings under the wireless tab.
For this you will need to access the setup page of the router by entering 192.168.1.1.
See how to connect kindle to wifi
Dec 31, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Where is the password for the internet connection located on the cisco
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for username and admin for password5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.9. select saveand apply. then you are good to go.
Dec 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
I forgot my password
Are you looking for wireless network password?
To find the wireless network key WEP WPA , you need to access the setup page of the router and check the wireless security settings.
Dec 13, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I lost y E1000'spassward and cannot access wireless connection
Have you installed Cisco connect software while setting up Your E1000 router?
If you have installed the Cisco connect then you will find all the settings there. If not then you can open the setup page of the router and check the wireless settings. Read Linksys E1000 Cisco connect
Nov 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I forgot my e1000's passward and lost wireless connection. How do I get passward for it?
you will need to access the setup page of the router and check the wireless settings manually. On the wireless tab you will find the WEP WPA network key
When we originally set up this router we did not password protect it but would now like to? what do we do?
I suppose you mean to protect your wireless network. In that case, you need to go to your router's configuration by typing the router's IP address in any web browser (like IE or Firefox) and look for configuration tab called "Wireless Security". I recommend you use WPA to protect your network.
Apr 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Need wpa passphrase
To get the WPA passphrase of the Cisco Linksys E1000 Wireless N router, you need to have a computer that is wired to the device. Log in to the router's setup up page by opening a browser then type in 192.168.1.1 on the address bar. Leave the Username blank and on the Password type "admin". On the setup page click on Wireless then on the sub tab click on the Wireless Security. You will see then the WPA passphrase.
Jan 15, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Can't get laptop to connect
check the wireless settings of the router. The wireless security might be set to WPA2/WPA mixed. Open the cisco connect software and check the wireless settings. If you are not able to change the settings using the Cisco connect software then you change the settings manually by opening the set up page of the router.
Click Here for step by step instructions
Jul 16, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
188 people viewed this question
Top Cisco Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Resolution IT Dubai
Resolution IT Dubai
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
