Question about Dymo RhinoPro 5000 Thermal Label Printer
I can not get my Rhino 5000 to print type size larger than "S" even when using the 3/4" tape
Posted by ggarciarib on
Nicky
    New Friend:
You must delete lines before changing to higher sizes. If you have more than one line the options, you have to put your cursor on the lower lines and hit clear before the size will increase.
Posted on Oct 09, 2012
nikos pappas
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
I am sorry but you can not print with Dymo RhinoPro 5000 larger than S
Posted on Nov 25, 2010
Do we have to add oil to the gas in our yamaharhino 660?
The Rhino was released in 2004 and was offered with a 450cc or 660cc engine with a carbureted fuel system. The 450cc engine was based on the Kodiak 450 ATV engine architecture, and the 660cc engine was based on the Grizzly 660 ATV engine architecture. Both engines were modified for use in the larger Rhino chassis. In 2008 Yamaha upgraded the big bore Rhino to the 700cc fuel injected engine that was again borrowed from the Grizzly 700 ATV. Yamaha did not offer the 450cc engine size from 2011 to 2013. All engine configurations were single cylinder four-cycle designs, mated to Yamaha's Ultramatic transmissions. All Rhinos use an electronic speed limiter system to restrict the top speed of the machines to approximately 38 MPH (61 KPH So the answer is no, oil is added to 2 cycle engines.
Apr 23, 2018 | Garden
I have a PT-85.I am frustrated because it only prints size 1 & 2 letters. When I print any size larger it prints the first letter partially. Do I need a different tape or is my machine broken?
I'm thinking that if the print is larger than the tape then you will need a larger tape it it is available
talk the problem out with your local office supply shop
Apr 07, 2015 | Office Equipment & Supplies
Change to larger font on aol e-mail
AOL Mail is an email service provided to the customers of American Online as well as Web users.
When you print an email using AOL Mail software, you may notice that the font size either appears too small or too large.
AOL Mail gives you the flexibility to adjust the font size and thus, the size of the print.
Note that these instructions apply to AOL 9.0 or higher.
If you have an old edition, follow instructions from the link specified under Resources.
Launch your AOL Mail software from the Start menu or desktop shortcut.
Log in using your AOL screen name and password.
Click "Settings" on the top bar.
Click "Font and Text."
Click the font type drop-down menu to choose either a larger or smaller font type than the current one.
Click the font size drop-down menu to choose either a larger or smaller font size based on your preference.
Click "Save."
Hope this helps
Nov 04, 2012 | HP Computers & Internet
With Print Shop 23.1-If I am adding text inside a text box, say font 60 and I complete the line and press "Enter" to start a new line, the font # changes back to what it was previously. Then I have to
When using text boxes I typically type the entire box in the preset font/size and then double click the text or select all, and choose my fonts ,sizes, spacing, etc. afterwards. Typically I use text boxes for smaller font items as I find the headline feature to be the most useful for larger size text. also under the text tab , after you double click your text box, you can select a paragraph style which has presets up to 143. I apologize that I didn't really answer your question, but maybe this will you get you by until you do, that is if you haven't already figured it out.
Oct 18, 2011 | Broderbund The Print Shop 23 Deluxe
What does "Text too high"
When you push the print button, "TEXT TOO HIGH!" error message appears on the LCD display, why? Description: This message appears if the size of the text is larger than the width of the installed tape.
Please reduce the character size or install a wider tape.
Aug 12, 2011 | Brother P-Touch 1180 Label Printer
How do I get my printer to print in larger text
You need to change the size of the text on your computer in order for it to print in larger text. You didn't say what you are using to print text so it's kind of hard to tell you exactly what to do. If you are using Microsoft Word or almost any word processor, you will need to change your font size to something bigger. If you are changing something that you've already typed, you can highlight or select what you have typed and change it's font size. Hopefully this is enough to help you. If you need further help, please let us know what software you are using to create your documents. Good luck!
Mar 13, 2010 | Lexmark P6350 All-In-One InkJet Printer
Printer using small type font size when printing from web pages
I am sorry to say that font size cannot be changed from the All-in-One software. It can only be changed from the application which you are using to print.
you can use Smart Web printing software to print webpages:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00793678&cc=us&lc=en&dlc=en
also, perform the steps below:
Change Text Size in Internet Explorer
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Size" option from the drop down menu. Use the mouse or press the x key.
A sub menu option window will appear containing the following five choices: "Largest", "Larger", "Medium", "Smaller" and "Smallest". "Medium" is the default value.
3. Select from among the five options by using the mouse to highlight or by pressing the appropriate keyboard letter, i.e. g for "Largest", l for "Larger", m for "Medium", s for "Smaller" or a for "Smallest."
The size of the text displayed in the browser window will change in accordance with your choice.
Change Text Size in Mozilla/Netscape 6+
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse or Windows users can press the ALT + v keys. A drop down menu will appear.
2. Select the "Text Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu window will appear containing three sets of options for changing displayed text size:
a. Increase or decrease the text size by small amounts. Select either the "Smaller" or the "Larger" option. Use the mouse to select "Smaller" or "Larger"; alternatively, press the appropriate
shortcut: CTRL - (minus) for "Smaller", CTRL + (plus) for "Larger". The size of text displayed in the browser window will increase or decrease by small amounts in accordance with your choice.
b. Change the text size to one of 7 pre-defined percentages of the default: 50, 75, 90, 100, 120, 150 and 200 percent. Select from among the 7 pre-defined percentages. Use the mouse to highlight your choice or the appropriate keyboard short cut, i.e. 5 for 50%, 7 for 75%, 9 for 90%, z for 100% (the default), 1 for 120%, 5 for 150% or 2 for 200%.
c. Change the text size to an arbitrary percentage of the default, e.g. 300%, 37.5%.
Select the "Other Options" menu item. Use the mouse to highlight your choice or press the o shortcut key.
A pop up input window titled "Text Zoom" will appear.
Type in the percentage amount by which you wish to change the default text size. Click on OK or press the ENTER key.
The size of the text displayed in the browser window will change in accordance with the value you enter in the input field.
These three options may be used separately or in combination.
Change Text Size in Firefox 1.0
1. From the Firefox Menu Bar select View>Text Size>Increase
2. This will cause the text to display on the web page one size larger. However this is a temporary change.
Or use the keyboard:
1. Press Ctrl & +/-, or Ctrl & scroll down/up to increase/decrease the text size.
To make a permanent font size change:
1. From the Firefox Menu Bar,
a. Windows: select Tools>Options. Select 'General'
b. Macintosh: select Preferences.
2. Click on 'Fonts & Colors'.
3. Set the font sizes. Minimum font size.can also be set.
Change Text Size in Opera
1. Select the "View" option from the main menu at the top of the browser window. Use the mouse to make a selection or press the ALT + v shortcut keys. A drop down menu will appear.
2. Select the "Zoom" option from the drop down menu. Use the mouse or press the z key.
A sub menu will appear containing the following options: 50, 80, 90, 100 (the default), 120, 150, 200 percent. In addition, there are four more options that make percentage increments or decrements to text size: -100, +100, -10 and +10 percent.
Select from among the options by using the mouse to highlight your choice.
* Alternately, use the + (plus) and - (minus) keys on your keyboards number pad, or the Zoom selector in the toolbar.
Mar 15, 2009 | HP PSC 2355 All-In-One InkJet Printer
ERROR appears and won't print
What size tape are you using in the machine?  Some of the fonts won't work if you are using 1/4" tape.  It will say ERROR if you're asking it to print a larger size. This won't be a problem for you if you switch to 1/2" tape, or just use the two smallest font sizes.
Hope that helps!
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Number of pages
If you use ALL small type, it will be 20 pages. Seems like the thing to do, but if you must use 21 pages, you can use 17 pages of small print (40,800), and 4 pages of large print (7,200) for a total of 48,000.
Oct 17, 2008 | The Learning Company Achieve! Math &...
Poor printing resolution...?!
You can select whatever resolution you want to print at on your Print(er) Setup.
If your Printer is automatically selecting a 72DPI to print at, you may be trying to print a 10X12 pic size or larger by default due to pic file size created when pic was taken in camera with full 7Meg resolution.
Use photo software to proper size the print before printing. If you want a print larger than 5X7, keep in mind the TZ3 begins to have recognizable noise, reduced resolution due to noise, especially in low light indoor or evening/nite outside shots. You can use photo software to improve and size them before printing. Windows Vista has a built-in photoshop type program. Else, I believe your camera comes with one on disk.
Also, read your manual regarding shooting with this camera.
Nov 09, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Dymo RhinoPro 5000 Thermal Label Printer Logo
717 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
