Question about Yamaha Emx88s Powered PA Mixer System
Can I plug just one subwoofer into my Yamaha EMX88S? What kind of sub do I need to get for it? Do I need to have 2 subs plugged in for it to sound right? Do I daisy chain the subs with the A15 speakers I have or use the stereo output on the front?
Matthew Spark
    Genius:
  • 1,066 Answers
It is not reccomended to daisy chain passive subs with main speakers, because there is no crossover unit involved. you want a sub to have a crossover frequency around 100hz, so that only frequencies lower than this go through the subs, and not in the main speakers.
you could get away with 1 sub plugged into the mono output on the front, subs dont have to be stereo. you would need a self popwered sub, or an additional amplifier+crossover for passive subs. your best bet would to be to get a powered sub and hook it up to the front panel mono out. powered subs usually already have the crossover built--in.
Posted on Nov 25, 2010
Testimonial: "Great thorough answer. =D "
  • Anonymous Nov 25, 2010
    i am new to all of this so please excuse my ignorance. The only outputs on my EMX88S are Monitor, REC OUT, and 2 Stereo outputs (L and R) Where would I plug a sub in this situation? How do I get it to do just bass and my main speakers to do the rest? Once again I am very new to this =/
  • Matthew Spark
    Matthew Spark Nov 26, 2010
    you would plug the sub, if you had one, into the monitor output for mono sound. this will not be a powered output, so you will need either a passive subwoofer/power amp/crossover components, all seperate, or you will need a self-powered sub with the amp and crossover built in.
    the crossover is what will make sure that ONLY bass is coming into the subwoofers. there is, unfortunately, no practical way to cross over the main speakers, so you will have to turn the low frequencies down on the main board eq to get some of the bass out of the mains. if the corssover on the sub is at, say, 120 hz, then use the board main eq to pull those frequencies around and under 120hz out of the main speakers.
    if you have 2 subwoofers, hook them up to the front panel stereo outs, instead of the mono monitor out. again you will need either need active subs with built -in crossovers and amplifiers, or you will need seperate passive subs/crossovers/amps components.
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I can't get my reciever to play my subwoofer
The sub channel will be switched off. You need to find the speaker settings, locate the sub channel settings and switch it on.
Jun 16, 2017 | Yamaha RX-V663 Receiver
Just purchased the Yamaha RX-V765 receiver. Have
I too have purchased the same receiver and have the same speakers. Did you get a good solution to this problem and how does it sound?
Jul 26, 2010 | Yamaha Audio Players & Recorders
There is no sound coming out of the subwoofer
I assume it's an active subwoofer, since it hums. Did you activate sub in the receiver menu? Did you turn up the volume on the sub?
Jul 08, 2010 | Yamaha HTR-5840 Receiver
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Wharfdale moviestar 70 speekers and sub
i have the same moviestars 70+ plus a yamaha rx-v750 put the crossover on the sub to maximum (left knob) volume (right knob) about 2/3 clockwise. change the crossover on the yamaha to anywhere from 80-120 ( the 120 will put more bass to the sub) if your yamaha has sub level/volume control set it higher, also if it has LFE/sub out set it to sub only.
Dec 17, 2008 | Wharfedale Moviestar 70+ System
My computer sound system
Most likely the sub has the crossover in it, most likely the 2 input cables from whatever device you want to play through the system will plug into the sub then the 2 speaker cables will come out of the sub and go to the speakers, just be sure to have everything connected into and out of the sub and make sure the power cords for the speakers and sub are plugged in, I am assuming this is a self powered system wich means the amplifiers are built into the speakers and sub.
Aug 07, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
DCM SUBWOOFER PROBLEM.
telll sterio use sub out and remix on in settings menu on steiro ok also does it have speaker wires in and out use them off fornts ch from sterio then back up throw sub to fronts set cross over on 100 or so
Jan 29, 2008 | DCM KX-6 Speaker
Yamaha Emx88s Powered PA Mixer System Logo
531 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
