Hi there.
go to this link might help you find out whats gone wrong.
HP DV6000 laptop dvd drive isn showing up in my computer Google Search
SOURCE: Can't get sound from an external device
the hp and compaq laptops i have the compaq, they have one thing in coman and that is that the mic input have no real control and i dont like it.i am curently working with this problem as well. but if i find anything out i will let you know. my email is [email protected]
SOURCE: cd/dvd rom not working on hp laptop
Is the Drive detected in the BIOS? Can you boot from your Windows or any bootable disc? If so try this solution:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find
"UpperFilters" and "LowerFilters" (and "UpperFilters.bak"
"LowerFilters.bak", if they exist) value under the following key in the
registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
SOURCE: unable to use cd/dvd drives , device manager blank
Hmm.. Yea Compaq was pretty tight in not providing a XP disc, um ill provide a link so you can download the HP drivers suited to your laptop and this may fix the problem in itself. If this fails, you may need to just install a fresh OS, but its kinda a problem since you didnt get a disc. Its a good idea anyway to also call HP if its under warranty cause it sounds like a case that warranty should fix up
XP Drivers Link
SO what i would do is pretty much install all of those drivers, then if your still having trouble call HP and get a warranty job on it if you still have warranty
SOURCE: HP 530 Laptop CD/DVD Drive Not Working
Please buy new CD/DVD drive since it wont open you cant event check using media. Its a possible mechanical failure.
Testimonial: "Thanks that really helps"
SOURCE: I have hp pavilion dv6000 and my sound card
Remove the sound card driver from your computer and then install it back after the computer restart. Check your volume settings and the volume slider on your laptop.
