Question about Symantec AntiVirus 2010 Full Version for PC (20044097)
How to remove virus from my system? - Symantec AntiVirus 2010 Full Version for PC (20044097)
Posted by mohali_hassi on
dgsturt
    Guru:
  • 1,705 Answers
1) Go to filehippo.com dowloand, install and run "Microsoft malicious software removal tool". Follow prompts
or
2) Go to filehippo.com dowloand, install and run AVG. Follow prompts
If necessary download to and install from a USB drive.
Posted on Nov 25, 2010
How to remove shortcut virus
use Quick Heal Internet Security or Quick Heal Total Security to remove them download the full versions from the below link
http://xviruslab.blogspot.in/2012/09/quick-heal-2013.html
download and do a full system scan
Thank you
Keerthy
X VIRUS LAB
Nov 27, 2012 | Computers & Internet
How can i remove virus
Removing viruses, though technical, is yet a very simple process if all the required steps are properly followed.
The basic steps are:
  • Buy or download a reliable antivirus software
  • Install the antivirus software
  • Update antivirus software with the latest virus definitions
  • Perform a complete system scan
Install an Antivirus Program in the System What is Antivirus program? An antivirus is a program that searches for, identifies and removes potential viruses existing in the computer system.
Antivirus software: Some of the most commonly and reliable antivirus programs available in the market are -
  • Symantec Norton antivirus
  • AVG antivirus
  • McAfee Scan
  • Microsoft Antivirus
The antivirus software should be updated regularly to retain its effectiveness.
Before installing the antivirus, close all open applications and terminate any suspicious processes using Task Manager. Sometimes, you may need to boot into safe mode or safe mode with command prompt to delete suspicious programs and references to them in the Windows Registry (run regedit from the command prompt to open the registry editor).
Search engines are excellent tools to find out whether a certain process is harmful or not. You can also get steps on how to remove a specific virus manually.
Removing the virus beforehand might be necessary, as some viruses will not allow an antivirus to operate. However, if you are not successful, you may still continue with the installation.
Scan the System to Identify and Locate the Virus Usually, the antivirus will run automatically when the system reboots after the installation. Therefore, it might identify the virus automatically. Moreover, you may want to run a quick system scan to locate the virus.
Troubleshooting the Virus Infected Areas After the antivirus identifies the infected areas, the next step is to rectify those areas.
Methods of Eliminating Viruses
Generally, the antivirus adopts one of two methods to eliminate the virus:
  • Removing the virus - When the virus can be easily identified and can be removed without affecting other files, then the antivirus removes it from the host place.
  • Quarantine - his is done when the virus cannot be easily identified removed from the file and the removal of virus means the removal of the complete file. In this method, although the virus is not eliminated, it is rendered inactive by moving the file into "quarantine" and renaming it.
Perform a Full System Scan Even after the virus is removed from the system, the next step is to scan the whole system to ensure that no infected files remain.
Aug 17, 2011 | Computers & Internet
How to remove shortcut virus in my laptop
Run Norton Anti Virus to remove viruses.
Jan 22, 2011 | Computers & Internet
I have an Acer laptop to work on that has numerous viruses on it and I was wondering if Acer D2D recovery will remove them?
system restore vs system recovery:
a system restore will restore the system to a set point in time. this will not remove viruses.
a system recovery will reinstall windows to its original factory state by utilizing a recovery partition. this will remove viruses. however, it will also remove any data and software that has been installed on the system.
back up if needed but keep in mind that you could potentially be backing up viruses. especially if the user wants to back up music that was gotten from a peer to peer site such as limewire. this downloads are typically ripe with infections so do so at your own risk.
it is not possible to back up software.
Dec 10, 2009 | Computers & Internet
Removing csrcs.exe virus
What you are referring to is probably the W32.Harakit virus. You can find removal instructions here:
http://www.symantec.com/security_response/writeup.jsp?docid=2008-102011-5014-99&tabid=3
Apr 06, 2009 | Microsoft Windows XP Professional
Infected with virus
Do you have virus software? If so go to the manufacturer and get the removal tool for that virus. If not download, install and update the free avast software with the link I have included. Do a full system scan and remove virus.
http://www.download.com/3000-2239_4-10793811.html
Jan 13, 2008 | Computers & Internet
My computer affected with virus trojan how can i remoove ?
first get any anti-virus I prefer F-SECURE, then load on your computer then update it after u pdate then perfom a full system scan then it will detect all the viruses,then choose delete option the it will remove all the viruses from your computer.Inform us after u try this solution.
Dec 16, 2007 | Computers & Internet
System corrupt made of virus and spyware
If you are having an issue with a virus go to: http://onecare.live.com/site/en-us/default.htm and run the scans. Try to remove any viruses found.
If it is a virus call Microsoft and they will help you remove it. It shouldn't cost to remove a virus.
Dec 01, 2007 | Computers & Internet
Trojan virus
you need to turn off system restore first as it backs itself up and then run your anti virus again, prefferably in safe mode, restart the pc and turn system restore back on.
Nov 19, 2007 | Microsoft Windows XP Professional for PC
Symantec AntiVirus 2010 Full Version for PC (20044097) Logo
480 people viewed this question
Top Symantec Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
