Press and hold the end of cycle signal-button for 3 seconds and it is ready to go.
It didn't work for me. I even held it down for 1 minute. The machine was running and something fell under the machine. I moved the machine and it stopped and the minutes just keeps flashing. I have unplugged it for 2 hours/ held the end cycle button down for 1 minute/ pressed the pause-stop button twice/ also held down the pause button then plugged it in. Nothing is resetting it. As soon as plug it in the minutes flash it sounds like its running but it wont spin.
Help!!!
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off.
To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
Instructions below:
