Televison & Video Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Element electronics tv model # flx - 2611b bad
Element electronics tv model # flx - 2611b bad powerboard 2 years old where do i get parts -out of warranty?
DILLIGAF
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Nov 25, 2010
DILLIGAF
Master
Level 3:
President:
Answers
1140
Questions
Helped
681285
Points
4145
Try ShopJimmy.com - they have a huge stock of TV parts. They are used but tested meaning they are usually much cheaper option and often have parts that are no longer available.
Power board: (verify correct part before ordering)
http://www.shopjimmy.com/polaroid-860-az0-mlt666amh-power-supply.htm
Picture of above part:
http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj860az0mlt666amh.jpg
List of available parts for your TV:
http://www.shopjimmy.com/catalogsearch/result/index/?q=element+2611&stock=all
You should verify the part number from your original board before ordering and also visually check that the replacement part matches your original. The part number is usually on a barcode sticker on the board or printed on the board itself. Be careful here as the number on the board may be the board number so try the find a part number if possible - the same board can be used for various configurations of components so is not a guarantee of being the correct part. Also manufacturers sometimes use different boards in televisions with the same model number according to price/availabilty/reliability.
You can also verify stock, part number, etc by contacting the supplier first. They may also be able to help you if you can't find your part on their website.
http://www.shopjimmy.com/contacts
Alternatively, once you have identified the part number, search for other suppliers by entering the part number into Google or Google Product Search. Be sure to enter the part number with any hyphens, spaces or periods as it is written on the board and if you have no success, also try the same search without any punctuation, e.g just the numbers and letters with no spaces.
http://www.google.com/products
Hope this helps.
Regards,
BElectric
Anonymous
Level 2:
Scholar:
  • Expert 114 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
114
Questions
0
Helped
23603
Points
370
Good Morning
That is most peoples first choice. If you know the numbers on the board
often times ebay will have used or refurbished parts.
Finally if you have an electronics guy in your town they can generally repair power supply boards.
Have a great turkey day
How do you remove the face of the element flx-2611b to replace the speakers?
Remove the back and you should be able to get at the speakers
No sound on tv
Under the menu option try factory reset..... then try the audio source, but the factory reset should fix it unless you are using a separate sound system.
My screeen has gone white on my tv how do i fix it on my element flx-2210 tv
White screen only / no picture is a sure sign of a failure in the power supply board. Your TV is getting power to the back lights but the control board voltages are not getting through so it is not displaying the picture right. This is an easy repair to do, you will just need to replace the filter capacitors on the power supply board. This Element model is actually made by Funai and is the same as the Polaroid FLX-01911c TV. Here is a repair guide for that model that will show you what needs to be replaced to get your TV back up and running again.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps you out.
BuddyMc
My element FLX 2210 has a problem. The tv turns on, but i cant see the picture, the sound is perfect. If you look closely at the tv you can see a faint image of the screen but not well enough to view...
This part should fix your problem.
http://cgi.ebay.com/ELEMENT-FLX-2210-Power-BACK-pt-200-000-XXXXTLTX-AH-VLC-/120527410872?pt=LH_DefaultDomain_0&hash=item1c0ffe56b8
2answers
Element FLX-2611B won't turn on. The red light is not lit
Just because fuses are intact does not mean it is not damaged. Sometimes a small spike of power does not blow a fuse but damages Transformer windings Before the fuse! If there are no lights picture or sound think powersupply transformer primary.
5helpful
5helpful
Element FLX 3202 no power
This was the same thing that happened to me. When I took it apart and checked the power supply the capacitor (largest on the board) was blown. I called Element Electronics, which turned out to be Polaroid, and they sold me the entire control box assembly for appx $115 with a $100 core deposit to ship my old assembly back. My core deposit was credited back to my account within 2-weeks. BTW, when mine went out I had no power light on at all. Lastly, If you have questions about doing this yourself let me know, while I'm no electrical engineer, I did a ton of research trying to solve the problem.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
