Question about Zanussi FJD1266W Front Load Washer
Zanussi FJDR 1266W Washing machine starts program at 54 by 51 starts to beep and error 90 displays i turn off machine and turn on again and it continues to wash but loses screen writing and then comes back saying 18 mins on display i turn off again and on again and 49 mins comes up and continues to wash but gets stuck on 49 mins what is wrong please and will the clothes be washed at all and how do i solve this problem
Posted by ballyhack on
My Zanussi Electrolux Essential 1200 washing machine ZWF12070W1
Most times unplugging a washer for 5 min or so will reset to factory. Some units just a quick unplug works too. But I'm not totally familiar with yours.
If it's going to be hard to unplug just turn off the breaker to it.
Hope this helps
Feb 27, 2018 | Zanussi ZWF12070 Front Load Washer
Hi! I have a Zanussi IZ12 washing machine. After I turn it on, the door will not open and start/pause button just flashes. (I can select program and press start/pause, it just beeps, but the machine do...
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Jul 14, 2010 | Zanussi IZ12 Front Load Washer
Can anyone help ive got a zanussi FJDR 1466 W. e91
I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
Nov 02, 2009 | Zanussi ZWF1430W Front Load Washer
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
My zanussi will not turn on at all.
If you give the facia a tap the display may come back on. You may then get an error code E90 being displayed. Either way you will require a new user interface pcb.
Nov 18, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi turbo dry 1200
Try cleaning out the pump, and main hose to sump. If problem persists replace pump.
Slim Jim
Nov 12, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJD1266W Front Load Washer Logo
366 people viewed this question
Top Zanussi Washing Machines Experts
peter gittos
peter gittos
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
