Roland Vs-2000CD Digital Studio Workstation System Logo
Anonymous Posted on Nov 25, 2010
How do i return my roland vs2000 to factory settings
  • Anonymous Nov 26, 2010
    how do i return my roland vs2000 to factory settings
  • Anonymous Mar 27, 2014
    CAN'T FIND DRIVERS
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Jan 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
479
Points
Call Roland's tech support, they will help you with anything you need. They're among the best in customer support 800-868-3737
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
I have a roland e96 trouble. Fist indikator in lcd internal battrey low, but not change the battey. now my roland e96 is blank.
You need to replace the battery. It will most likely be a coin sized battery in a slip in holder on the main board. If you need help, here is ROland Customer Service contact info-
Support Roland
After that, you can reset the E96 back to the factory settings by following the directions here-
Roland 96 Initializing the 70 86 96 Restoring the Factory Settings...
2answers
My roland vs 2000 says not found any drivers when i turn it on can it be fixed
I think your best option is to try downloading and installing the latest system update from the Roland Site link below.
http://www.rolandus.com/products/productdetails.php?ProductId=602
Roloand vs2000 hard drive crashed... where to get a new one or fix this one? We were recording and tried to play back, system them never booted and gets stuck while rebooting. Tried a new hard drive but...
Roland has excelent Tech support.
I might try with the Web site below -
http://www.rolandus.com/support/?tab=contact
Please let me know what you find and or re-contact me if you can't get anywheres with Roland only I think they will be more than happy to help.
Blessings,
A/V Media Guy
2answers
Roland VS2000 Doens't load project after power accident
turn it on and just let it load..it may take like 20 hrs or so but it will come on...and yea when it does you might not have anything that you had on there but you can start over and it will work like new..worked for me
C.D.
13helpful
NTL VS2000 phone instructions missing
you could cut and paste this link into your browser and you should find the manual
www.cordless-phones.uk.com/userguide/vs2000.pdf
Hope this helps
Top Roland Audio Players & Recorders Experts
 Grubhead
Grubhead
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
