you said you tried applying direct voltage to the pump? proceed to remove the fuel tank and check the harness inside for continuity, both wires going to the pump itself. If wires prove to be ok , then proceed to replace pump .
in manual mode, will not try to focus itself, my be the manual auto switch is faulty, or the focus related mechanism not rotating the lens, open the lens carefully check the focus motor and gear set (engine is the technical term)
STEERING WHEEL TILT LEVER ON LOWER LEFT OF THE STEERING WHEEL NEXT TO THE TURN SIGNAL SWITCH JUST LOOK FOR ANOTHER LEVER BELOW TURN SIGNAL SWITCH THATS YOUR STEERING WHEEL TILT LEVER. YOU CANT MISS IT UNLESS IT BROKEN OFF.
In digital photography, the focus error is especially an error message on Fujifilm FinePix digital cameras, usually caused by dirt in the lens mechanism. To avoid any further damage, the camera electronics totally disables the autofocus system and refuses to take any still image. If out of warranty, the repair costs can easily exceed US $100
If it's in continuous auto-focus and doing it, then it is just not locking on to one thing and jumping back and forth between two objects that are very close together in distance and it is normal. It should stop in manual, single shot or single point auto-focus. Sony uses Nikon auto-focus technology and my D-300 with a 70-200mmf2.8 will do it if I turn the auto-focus tracking time(lock-on) all the way down with the auto-focus in full auto.
hi from uk for your info the rear brakes assy's are auto adjust whether they are disc or drum brakes so h pe the garage are not adjusting the h/brake cable each time ? if so then the auto adjust will not operate due to cable holding the auto adjust mechanism and so the as brakes wear the auto adjust that takes up wear does'nt ? but you are pulling h/brake hard on to apply park ? and actually streching cable you should release cable then pump footbrake and provided?? theauto adjust and lever are not seized brakes will adjust and also will/should improve footbrake ie less travel and more positive then you can reset cable as per h/book hope this helps and is easy diy especially if you follow haynes or other manual ?
behind your front panel is two rows of small black knobs that adjust the lamps brightness and focus. a phillips screwdriver might be needed to turn them. you need to adjust the red guns focus.
