Wiper Motor
Removal & Installation
To install:
WELL ALL YOU HAVE TO DO IS REMOVE WIPER ARM COVERS OVER WIPER ARM MOUNTING NUTS. THEN MARK THE POSITION OF EACH WIPER ARM TO SHAFTTHEN REMOVE ARMS.THEN REMOVE THE WINDSHIELD COWL COVER DISCONNECT THE WIPER MOTOR HARNESS CONNECTOR AND REMOVE THE WINDSHIELD WIPER MOTOR LINKAGE ASSEMBLY MOUNTING BOLTS.LIFT THE WINDSHIELD WIPER MOTOR ASSEMBLY FROM THE COWL AREA.YOU CAN USE SCREW DRIVER TO PRY THE LINKAGE ROD FROM THE MOTOR.REMOVE THE WIPER MOTOR MOUNTING BOLTS SEPARATE THE MOTOR FROM THE ASSEMBLY.
Everything is great and logical, but for this world I could not figure out, what you seem to just fly over: REMOVE WIPER ARM COVERS OVER WIPER ARM MOUNTING NUTS.
So easy to say, but I could not see any nut or how do I get access to them? They seem to be pretty well hidden. Please explain in details.
FOLLOW WIPER ALL THE DOWN TO THE END OF IT.THERE SMALL COVER THERE.LIFT COVER UP AND YOU WILL SEE WIPER ARM NUT.USE SOME WHITE OUT.MARK POSITION WIPER ARM BEFORE REMOVING SO IT CAN BE INSTALL IN THE RIGHT POSITION.
