Whirlpool MH2155XPS Microwave Oven Logo
Posted on Nov 25, 2010
Whirlpool MH2155XPS Stainless Steel 1000 Watts microwave suddeny is making a loud vibrational noise. lights come on but sounds like it is ready to blow up. ideas?
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 29, 2007
SOURCE: GE JVM1650SH Stainless Steel 1000 Watts Microwave Oven?
It sounds like you may have had an issue with a high voltage part such as the magnetron, diode, or transformer. It's also possible that you had an arcing stirrer. I would also check to see if your model is covered by / affected by this bulletin: http://microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf If you or a friend decide to work on it, we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Anonymous
  • 5911 Answers
  • Posted on Jul 31, 2007
SOURCE: Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 22, 2007
SOURCE: Whirlpool mh2155xps microwave door handle
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Your model does not show up. You can double-check it or look up model MH1150 - it should be close enough to help you see how it works. You may need to remove the choke, as shown in the attached sample drawing.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 21, 2008
SOURCE: Whirlpool microwave MH1170xsy0 1000 watts
With the symptoms you mention, I would suspect:
- loose or corroded connection at the magnetron
- bad magnetron
- shorted high voltage diode
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Anonymous
  • 87 Answers
  • Posted on Mar 04, 2009
SOURCE: Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Can you use metal pan if only on convection setting?
Microwaves penetrate most materials except metals which offer a ready path to the internal surfaces, so you would expect to see occasional flash overs using a metal pan, sudden surges like this will shorten the life of the magnetron.
The "under the microwave" light was on. All of a sudden, the light and clock stopped working. We have checked the plug and checked our fuses. Are there any troubleshooting suggestions out there? Thank...
There can be several fuses. Some on the board and some encapsulated in white plastic along wires. Do the buttons work (beep) when you press them? Is there any sign of life?
1helpful
Wmh3205xvs door handel
see the video and fix it. God bless you.
2helpful
My whirlpool gold gt4175sps lights up and the control panel works but the turntable does not spin and it does not cook. No fan or cooking noise
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
2helpful
My microwave has power, but it will not heat anything. What could be causing this?
Basic
heatman101
Whirlpool MH2155XPS-0 does not work. Outlet and breaker are fine. Is there an internal fuse?
Yea there is a fuse behind the control panel. Remove vent loover then remove srew that holds control panel it will lift up & out the fuse will there somewhere. good luck
There is power but it is not heating anything and after about 10 seconds it makes a very loud noise.
If it's making a loud buzzing like sound it's the component that sends waves through the microwave. This piece is about $120 plus they charge about $65+ to install it. Also some charge the diagnostic fee of about $75. Either way, once a microwave goes out it's pretty much useless to repair one unless you have put a lot of money into it. We had ours to do the exact thing you describe and it was cheaper to buy another and me install it basically because I was getting another 2 year warranty as to the other had run out.
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
