Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
Will a nicd charger work to charge lithium-ion batteries?
Posted by sandman2266 on
  • ben gielen Jun 08, 2018
    By an imax b6ac and you are able to charge any battery
Anonymous
    New Friend:
  • 8 Answers
No, I would not try this. You can charge a nicd battery on a lithium-ion charger but not the other way around.
Posted on Nov 29, 2010
Will the P110 charger charge a lithium ion battery
No, the P110, 18V NiCad battery charger, will not charge a 18V lithium ion battery. You need one of the dual-chemistry chargers. If you have the Ryobi ONE+ batteries, you can get the P117 charger ($30) or a charger with an extra battery (P126) from a store like Home Depot. A 6 battery charger and a 12V in-car charger are also available.
I wish that I had better news for you.
(who has the Ryobi 12V drill and charger, a few of the 4V tools, and a number of the ONE+ 18V devices and chargers. The single chemistry battery charger is not used much any more.)
Nov 24, 2012 | Ryobi Two 18V Lithium-Ion Batteries +...
18 volt dewalt lithium ion battery charger stopped working for no reason....
This can happen if the battery is too dead for too long. Keep trying to make it work like you have maybe 20-30 times. Or you can leave the battery in for a few days and let the logic chip do it's job. It should start working in a day or two.
Apr 25, 2012 | Dewalt Dc9310 7.2 Volt To 18 Volt Nicd /...
Can I charch my new ryobi batery lithium whith the old charch
NO THE OLD CHARGER FOR THE BLUE ONE+ TOOLS WILL ONLY CHARGE NICD BATTERIES. HOWEVER THE INTELLIPORT DUAL CHEMISTRY CHARGER WILL CHARGE BOTH NICD AND LION BATTERIES. ALL BATTERIES ARE COMPATIBLE WITH ALL ONE+ TOOLS
Mar 01, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
DEWALT DW938 18VOLT CORDLESS SAWZALL can it use Lithium Batteries
As long as the voltage of the battery is the same as the tool, the tool won't mind if the power is coming from a NiCd or lithium battery. You do have to have a charger that works with lithium batteries to charge them up. Chargers that can charge lithium batteries can also charge NiCd and NMH batteies. NiCd chargers are not always programmed to detect when lithium batteries are full and may continue to charge them to the point of melting or starting on fire.
Jan 31, 2011 | Dewalt Dw938 18v Cordless Reciprocating...
What Ryobi batteries p103 or p104 will a battery charger that came with my p100 batteries charge? Or will the charger work with these batteries?
If you have a P100 NiCad battery, the charger for that will not charge the new Lithium Ion P103 or P104 batteries. You need a specialised Ryobi Lithium Ion battery charger like this one
Jan 11, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Can you charge a 18v lithium battery in a nicd charger?
Do not try this since the charging circuit for lithium batteries are different than nicad! Improper charging of lithum batteries can cause a fire.
Dec 06, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
One of my Ryobi 18v battery packs (1400672) won't charge, the chargers red and yellow lights stay on. How can I trick it into charging?
Use
AC / DC Power Adapter Replaces Ryobi One+ Batteryhttp://lcdpayless.com/ryobi_one_power_adapter.php
Oct 22, 2009 | Ryobi Drills
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
619 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
