2001 Chevrolet Cavalier Logo
Posted on Nov 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you replace the Driver's side power window motor on a 2001 chevy caalier
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Nov 24, 2010
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833718
Points
6040
Before replacing the motor I recommend that you verify that the switch is functioning properly. Replacing the switch is considerably easier than replacing a window motor.
Here is a description of what to do to replace the electric motor in the driver's power window on a Chevrolet Cavalier.
1. Remove the interior door panel. There are two screws in the arm rest and four around the sides and bottom of the panel. Disconnect the window door lock cable from the switch on the door.
2. Remove the sound system speaker by first disconnecting the electrical cable and then removing four screws.
3. Remove the plastic water shield. The shield is held in place with an adhesive that behaves like bubble gum. Pulling the plastic shield away from the door causes the adhesive to become stringy like bubble gum. The nice feature of this is that some adhesive adheres to the door and some to the shield so that during reassembly the shield sticks well to the door. During removal use a razor blade to cut the strings to help reduce any mess. Some of the shield was caught under the door panel armrest support so that it was necessary to cut the shield to completely. Rather than cutting the shield just folded it up and taped it to the door. Be careful of what comes in contact with the adhesive because after a few hours of contact the adhesive sticks to almost anything. It even stuck to the wax paper placed over the adhesive to keep it from attaching to anything it came in contact with while removing the window regulator/motor assembly.
4. Remove the window glass. There are two nuts holding the window glass to the window regulator. It is easiest to have the window positioned about half way up to allow access to the two nuts. The window glass can be pulled out of the door by lifting the rear edge of the glass first.
5. Disconnect the electrical connector from the window motor.
6. Remove the window regulator and motor assembly. This will require an electric drill and some drill bits to drill out the 5 rivets. There are two bolts that attach part of the window regulator to the door. These need to be removed as well. Once the rivets and bolts have been removed the entire assembly (window regulator and motor) can be removed through the large opening near the rear of the door. It may not look like it will fit, but it does. The most difficult part of this repair was locating rivets to replace the rivets that are removed. Be careful to find replacement rivets that are the same length as those that were removed because at least two of the rivets could interfere with the moving parts of the window regulator if they are too long.
7. Remove the window regulator from the motor. There are three rivets that hold the window regulator and the motor assemblies together. Remove the rivets by drilling them out. These rivets can be replaced with screws from the local hardware store if you prefer not to use rivets.
8. Attach the new motor to the window regulator assembly using rivets or screws. Use stainless steel machine screws and nuts along with a lock washer under each nut. Choose whatever attachment method you prefer.
9. Lubricate the window regulator with white lithium grease.
10. Reinstall the window regulator/motor assembly in the door.
11. Plug the electrical connector back on the window motor.
12. Reinstall the window glass. Insert the front edge first to make this easier. Reinstall the two bolts holding the glass to the window regulator.
13. Test the new motor by opening and closing the window to ensure that it is operating properly. If not, resolve the problem and continue.
14. Reinstall the plastic water shield.
15. Reconnect any electrical connections.
16. Reinstall the sound system speaker.
17. Reinstall the interior door panel. Remember to reconnect the power lock connector.
The job is complete.
2003 Chevy Tahoe. Driver side front window. Won't go up or down.
Check your window switch operation. Pull door panel off and check for power/ground at window motor plug. If power is present, replace window motor. If no power/ ground, check switch operation and wiring from switch to window motor..
4answers
2002 corvette - driver power window stopped working
had the same problem, everything worked but the driver side window and door lock, I had it diagnosed at Chevy dealership and the problem was the driver door control module. the price from Chevy was around $ 775. I found the part new on eBay for $150 and had Chevy install it for $98. hope this helps ebd77b2d-cb07-4929-8fe7-e40939c07e85.jpg
1helpful
2answers
Electric car windows will not close properly -every onr of them
POWER WINDOWS NOT WORKING & POWER WINDOW/REGULATOR ISSUES
It can be issue with motor itself. If it's not going up, then how its working down. But still it feels like weak window motor or is issue with power window switch. Get the voltage tested at switch and motor. Also try another working window motor at not working window side.
For more troubleshooting i suggest go through the help links mentioned below:-----
Its complete details with troubleshooting steps:------
Car windows will go down but come right back up
http://schematicsdiagram.blogspot.com/2011/06/car-windows-will-go-down-but-come-right.html
Power windows will not go up and relay clicks when switch is pressed?
http://technoanswers.blogspot.com/2012/01/power-windows-will-not-go-up-and-relay.html
Electric Window Motor REMOVAL and INSTALLATION on ford vehicles?
http://schematicsdiagram.blogspot.com/2011/06/electric-window-motor-removal-and.html
Driver side power window wont go up on ford expedition?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
How to replace window motor and regulator on jaguar S-Type?
http://howtobyme.blogspot.com/2011/09/how-to-replace-window-motor-and.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
power locks, power window and power mirror on the passenger side not working on Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working on 2003 Cadillac CTS?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove the door panel to install a new window regulator on Cadillac Deville?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
How to Remove Electric Window Motor on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-electric-window-motor-on.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
How to replace power window regulator for 2006 Dodge Dakot
How to remove passenger side power window motor on Dodge Grand Caravan?
http://schematicsdiagram.blogspot.com/2011/09/how-to-remove-passenger-side-power.html
How to replace automatic window motor unit for the front passenger side on 2001 jeep grand cherokee Laredo ?
http://schematicsdiagram.blogspot.com/2011/09/how-to-replace-automatic-window-motor.html
how to replace passenger side power window motor on 2001 Dodge van
All power windows not working on mercury sable?
http://technoanswers.blogspot.com/2011/09/all-power-windows-not-working-on.html
How to replace electric window regulator for mitsubishi 380 ?
http://technoanswers.blogspot.com/2011/09/how-to-replace-electric-window_05.html
how to remove window motor on driver side door panel on 1994 Oldsmobile Cutlass Ciera
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
driver side window problem on Mercury Sable
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
How to remove door panel, door window motor and regulator on 1991 cavalier?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
how to replace the power window switch on 2005 BMW 325i?
http://technoanswers.blogspot.com/2011/03/how-to-replace-power-window-switch-on.html
How to replace window switch on bmw?
http://technoanswers.blogspot.com/2011/03/how-to-replace-window-switch-on-bmw.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
How to Replace a Window Switch on a 2002 Ford Explorer ?
http://technoanswers.blogspot.com/2011/02/how-to-replace-window-switch-on-2002.html
Ford F-150 Power Windows Not Working?
http://schematicsdiagram.blogspot.com/2011/12/ford-f-150-power-windows-not-working.html
Power windows works intermittently?
http://schematicsdiagram.blogspot.com/2011/12/power-windows-works-intermittently.html
Pontiac grand am power window not working?
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
Auto open close feature not working for Toyota Avalon?
http://technoanswers.blogspot.com/2012/01/auto-open-close-feature-not-working-for.html
Lexus ES300 Power window out of time?
http://repairhelpcenter.blogspot.com/2012/01/lexus-es300-power-window-out-of-time.html
Rear power windows not working on Ford Mustang?
http://technoanswers.blogspot.com/2012/01/rear-power-windows-not-working-on-ford.html
All power windows not working on Ford Explorer?
http://technoanswers.blogspot.com/2012/01/all-power-windows-not-working-on-ford.html
2003 Chevy impala power windows not working?
http://technoanswers.blogspot.in/2012/02/2003-chevy-impala-power-windows-not.html
Diagnosis & Testing Power Windows?
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
All Power Windows Not Working
http://whatisbyme.blogspot.in/2012/07/all-power-windows-not-working.html
1977 Chevrolet Corvette Power Windows Not Working?
http://technoanswers.blogspot.in/2012/04/1977-chevrolet-corvette-power-windows.html
These details will help.
Thanks.
1helpful
2answers
How do i change the drivers side window motor an an 05 kia sedona
You have to remove the inner door panel to
access the window regulator
You remove the regulator & then the motor from it
You Tube Video will provide a visual of several
similar window motor replacement jobs
Go there-- enter your car,question ,details,etc--- then move
around the site to watch various things
Thank yo for the schematic Ernesto. It says Nissan 1996, so is the 2008 still using the same schematic?
It can be issue with motor itself.If its not going up,then how its working down.But still it feels like weak window motor or is issue with power window switch.Get the voltage tested at switch and motor.Also try another working window motor at not working window side.
==========For more troubleshooting i suggest go through the help links mentioned below:-----
--------------How to Remove Electric Window Motor on Acura Integra?
Laredo ?
These details will help.Thanks.
Driver side window not working on a 2001 chevy xtreme blazer. The passenger side window works fine, but the driver window is stuck halfway.
Sounds like you are in need of a window motor/regulator.They are built together and should be replaced as a unit for the best results.It is inside the door and the door will need to be disasembled to get to it.I would recommend a service manual if this is something that you are going tackle on your own and havnt done this before.let me know how it goes.
1helpful
2001 1500 silverado power window
no. all the windows get their power from the driver switch. you need to actually check the circuit..using a volt meter check for power and ground..you are missing one of them..
2helpful
2answers
2005 chevy impala rear driver power window stopped going up.stuck
If neither switch works it is a bad connection at the motor or bad ground or a bad motor. Remove the door panel unplug the motor push the switch and see if there is 12volts on the wires if there is the motor is bad There are small brushes in the motor that go bad tap on the motor while pushing the switch if it works that way replace it
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
