Question about Fuji FinePix S7000 Digital Camera
Why transcent cf 4 gb cart give problem in my fuji s7000
Posted by e_pekon on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
The S7000 is designed to work only with memory cards up to 2GB in size. It's not supposed to work with 4GB cards.
Posted on Nov 24, 2010
Can i use cf 4gb 200x in fuji s7000
No, the maximum capacity CF it can handle is 2GB.
Jul 01, 2011 | Fuji FinePix S7000 Digital Camera
Can I use 1 mb sd picture card
No. S7000 can use XD cards (available upto 2GB) or CF cards up to 1GB
Mar 24, 2010 | Fuji FinePix S7000 Digital Camera
Does the Fuji s7000 camera support media cards bigger than 2GB?
No 2GB is the max size for XD card and CF card, You can fit type 1 and type 2 CF cards even though the cover says type 2
Jan 26, 2010 | Fuji Rod Repair Kit
What if a new memory card wont initialize?
Hi
The reason you are having this problem is that the maximum size memory card supported by this camera is 2GB. Any card with a larger capacity - like your 4 GB card - can not be initialised by the camera.
For reference see
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Fuji/Fuji+Finepix+S7000+Zoom_Memory_Cards
Hope this helps. Please do remember to rate my answer. Many Thanks.
Jul 25, 2009 | Fuji FinePix S7000 Digital Camera
My Fujifilm S9600 draining batts rapidly...
Hi !! With your comments I was thinking on al old problem that I have with a Fuji S7000 using a CF card, it drains the battery very fast, but the problem was the CF card, not the camera, I switch to a XD memory card and problem solved, Are you using a CF memory card?
Apr 13, 2009 | Fuji Rod Repair Kit
Can't initialize SanDisk Ultra II for S7000
It looks as though the camera cannot support memory as high as 4GB. Capacities above 2.2 GB require that your camera supports "FAT32", and S7000 does not support FAT32.
Dec 30, 2008 | Fuji FinePix S7000 Digital Camera
4 GB CF will not initalise
Yea I have the same camera, and this camera only will works with a maximum 2gb card, because the camera uses fat16 format, and fat 16 will only adreeses up to 2 gb.
new models works with fat32 then they will works with bigger cards.
Dec 10, 2008 | Fuji FinePix S7000 Digital Camera
How big of memory cards will work with the FUJI S7000
The easy answer is..... 2 Gb.
The longer answer entails fat16 vs fat32 abilities, and the posibility of reformatting your card on the computer in an attempt to possibly get the s7000 to recognise it with mixed success. Since the s7000 is fat16, it can recognise only 2Gb of data.
The xD cards max out at 2Gb. CF goes much higher, but only 2Gb will be recognized.
On a related note, if you do continuous shooting or movies and use an xD card, make sure you get the H-type (not M or M+) as this is higher speed and will avoid timing issues. All of the newer CF cards are plenty fast already.
HopHead
Nov 03, 2008 | Fuji FinePix S7000 Digital Camera
SanDisk Ultra IICF 2.o GB
on pc, try using the utility [format] when card found under "My Computer"
May 20, 2007 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Rob Hill
Rob Hill
Are you a Fuji Camera Expert? Answer questions, earn points and help others
