Question about Canon Elura 60 Mini DV Digital Camcorder
When I turn the camera to the "Camera" or "Play
Posted by cjmonahan on
ONE-Touch-Solution
  • Canon Master
  • 1,679 Answers
Gently tab on camera on palm for 3-4 times. Turn off and turn on. It should work fine. Also try with a new battery cells if you can.
Let us know if the issue is resolved.
Thank you for contacting FixYa.
Posted on Nov 24, 2010
Sony cyber shot digital camera probelem-- message
Lens is stuck out of position. Usually useless to turn on and off. IC overheated
Feb 10, 2012 | Sony Cameras
Kodak Easyshare z730 - possible problem flexible flat cable. I had a recent problem with a stuck power/mode dial turning too far past the video mode. I was successful in carefully opening the camera and...
It's obviously a switch problem, not a ribbon (which controls the lcd screen) problem. Start doing your research to find that "perfect" camera. Read all the reviews to see what actual owners think in addition to the experts. Or......you can "limp along" until you get tired of that.
Oct 05, 2011 | Kodak EasyShare Z730 Digital Camera
I have a number of VHS-C tapes from my various video cameras in the early-to-mid 1990s that I'm transferring to DVD via my DVD/VCR combo device. But several of of these tapes that have the suffix...
VHS-C and S VHS-C are two different animals. Super VHS-C will have much better video resolution than standard VHS and uses better videotape. A standard VCR will not play the Super format. You need a S VHS VCR. You would need not only a S VHS VCR but also a S VHS-C adapter. Yes, Not even the adapter is the same as a standard VHS-C adapter cassette.
You can send out your few S VHS-C tapes to a video conversion service. That might be the least expensive way to get them on DVD. Otherwise you could look on E-Bay.com for either a compatible camcorder (S VHS-C) or the S VHS VCR and the S VHS-C adapter.
http://vhs-to-dvd.com is one video conversion service that should be able to get your tapes on DVD for you. You could also look locally for a video service that does conversions to DVD.
Feb 19, 2011 | Televison & Video
Lens wont go in
I had the same problem, my workaround was:
1. turn on the camera, you will hear some beeping as the lens tries to raise from the body of the camera
2. wait until the camera turns off
3. pull the lens gently until you hear a 'click'
4. turn on the camera again, it will work normally (hopefully)
Another interesting thing, you can switch on the camera in "play mode" only, by holding down the play button on the back while pressing the power button. In that way, the lens will not raise and you can copy the images.
May 24, 2010 | Polaroid i735 Digital Camera
The cassette is stuck and the player will not eject it. when you turn it on it just makes a beeping noise.
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
Aug 11, 2009 | Sony Hi8 CCD-TRV138 Camcorder
XH-A1 Stuck in Lock Mode?
Take the camcorder apart then press the button inside it because it seems there is a plastic peice broken on the button.
Apr 10, 2008 | Canon XH A1 Mini DV Digital Camcorder
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
Canon Elura 60 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
