Ricoh Aficio 450 Copier Logo
Anonymous Posted on Nov 24, 2010
I cannot set the time fax number and name on ricoh aficio 450. Please only realy solution not from another aficio
MSM
Level 2:
New Friend:
  • Expert 165 Answers
  • Posted on Nov 25, 2010
MSM
Expert
Level 2:
New Friend:
Answers
165
Questions
0
Helped
76571
Points
291
Send me ur e mail ill send u the fax manual for it
My e mail is [email protected]
Please may I get the part number for network board for ricoh aficio 450
1394 interface board~~~~~~~~~ G336
USB 2.0 interface board~~~~~~~ B525-01
& IEEE 802.11b wireless LAN~~~B525-01
1helpful
I need to reset the terminal name and number on the fax portion of the Ricoh Aficio 450 copier. Can anyone assist what that?
The fax user manual for the 450 is no longer available from Ricoh, so I can't check for sure, but the basic procedure is to press the User Tools button, go into Fax Features, and under one of the tabs will be a box where you can change the fax header information.
Hope that helps!
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mp33/mp33en.htm
2answers
Cannot find confirmation page "on off switch" Ricoh Afico 2035esp
User Tools/Fax/Parameter Settings. Personally I wouldn't mess with those, it's to easy to totally mess up the fax system if you flip the wrong bit switch setting. I threw my 450 programing guides away some time ago being that there's just a hand full of these things left in the hole country. I believe if you go to Ricoh's web site and go to the download page, you can download the fax user manual which if memory serves me (and it often doesn't), you'll find how to change the fax parameter settings.
3helpful
Phone # on outgoing faxes
"user tools"
"fax features" ok
"general settings" ok
"program fax info" ok
"own fax number" ok
enter number..press "ok"
Please rate solution. thanks :)
3helpful
Trying to change a fax number in memory
To change info:
"user tools" (ok)
"fax features" (ok)
"general settings /Adjust" (ok)
"program fax info" (ok)
...then set name, number, etc.
"user tools" to exit
To print speed dials:
"user tools " (ok)
"fax features" (ok)
"reports / lists" (ok)
"dial list" (ok)
"Quick dial list" or "speed dial list", etc (ok)
I hope I'm your Hero now :)
Please rate me.
1helpful
Dove posso acquistare ricambi per gestetner 3235 aficio - napoli
You should call in to Ricoh Italy official sales ofice
The address and phones are as follow:
Italy
Ricoh Italia
Viale Martesana, 12
20090 Vimodrone (MI)
Tel: 02.91987.100
Fax: 02.91987.555
Si dovrebbe chiedere a Ricoh Italia ufficiali di vendita ofice L'indirizzo e telefono sono i seguenti:
3helpful
Change the time of the fax on a Ricoh Aficio Super 220
Set date and time;
  • Press User Tools/counter button
  • Press 3 for Fax
The Facsimile User tool main menu appears.
  • Press the number 6 for Key Op. Settings and press the hash key within 3 seconds.
  • Press 18, Date and time or next until it shows.
Select month, date, year or time with arrow buttons,
enter the month with Prev. or Next and enter the correct time and date.
Press OK > PrevMenu > User tools/counter button.
Good luck and please rate me, thanks.
1helpful
Ricoh Aficio 450
Press the diamond button to the left of the display then press number press next until you see number 6 marked configuration then press number2 tcp/ip input your ip and subnet press the #button to set the data cheers dr bob1
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
