Question about General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
I cant set timer lost manual model 15086 can you
I cant set timer lost manual model 15086 can you please e-mail manual
Posted by engineering0 on
Anonymous
Can i down load the instruction to reprogram my timer.Gemodel#15086
Hi and welcome to FixYa, I am Kelly.
You can get the manual here:
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | Hardware & Accessories
I need to wire a GE #15086 programable timer into a 2 pole/ 3 way circuit.can it be done and how?
You want to wire GE 15086 timer in place of 3-way switch.
You do not have correct timer for the job.
GE 15071, 15086, 15065, 15066 series in-wall timers are for single-pole only.
Open following link to see GE timers and list of timers & manuals for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Timers made for 3-way are for indoor use only and not cold weather applications. This is because these timers use a battery or rechargeable battery that will not perform long-term when exposed to cold temperatures.
Wiring for 3-way timers requires slightly different wiring at remaining 3-way switch. In other words, the timer replaces one 3-way switch, and the other 3-way remains, but wiring is different on remaining switch.
Look at manual carefully.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | Office Equipment & Supplies
I installed a digital timer GE 15086. Does it work with fluorescent lights?
15086 manual says 15A Tungsten.
Tungsten is incandescent.
manuals usually say CFL or fluorescent if they are made for those loads.
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Honeywell (500 watt/40 watt minimum) Aube T-1032 handles fluorescent and halogen
http://waterheatertimer.org/Aube-timers.html
Woods 59028 works with CFL
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Jan 16, 2011 | General Electric Hardware & Accessories
I have a GE smart timer 15086 I followed the instruction and the light blinks when you turn it on. Please help
I test timers, and no damage is done.
Sounds like you wired red and white wires together, or installed timer in place of 3-way switch.
15086 will not replace a 3-way switch.
For example, when 2 switches control hallway light, that is 3-way.
Link above has list of timers that replace 3-way switch.
How to wire 15071, 15086, 15265, 15266 timers:
1) Switch has 2 insulated wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push ON-OFF button located in each corner. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
For a price, fixya expert speaks with you over phone while you work on any do-it-yourself project.
Jan 10, 2011 | GE 60minute Automatic ShutOff Timer Switch...
Installed several GE smart digital timers around the house: for lights over garage, front door, court yard. They are model 15086. The units work in timer mode as desired. I would think...
15086 timer:
Pressing door will override timer setting and manually turn switch ON-OFF.
Press door or open timer door, and press any of 4 buttons located in corners.
You know information posted so far:
However, you are moving the small switch from Timer to OFF.
And when switch is OFF, the override does not work because circuit is OFF.
You want a timer that can switch programming OFF, and not switch circuit OFF, so that device toggles between timer and ordinary switch.
Looking at timers on the market today, I cannot think of any in-wall programmable or box timer that does what you want. Each has manual override that reverses timer function, but when you set timer to OFF, the circuit is OFF.
http://waterheatertimer.org/Programmable.html#Aube
Plug-in-type timers have override button that turns programming off, and then you can operate table lamp normally with the lamp switch. But in that case, the lamp has separate switch that operates outside of timer functions.
GE 15070 24-hour mechanical timer could do what you want:
http://waterheatertimer.org/images/GE-15070-mechanical-timer.jpg
In this specific case, when you wanted to operate timer like a light switch, you would move all the pins inward, and then use the on-off switch. The problem with this idea is the pins are tiny, and you need very good eyes or a light-source and small tool to continually adjust pins.
See GE timers and manuals:
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 07, 2011 | UPM Programmable Wall Switch Timer
GE 15 amp 7-Day In-Wall Programmable Digital Timer Model # 15086 Internet # 100685863 Store SKU # 543414 ------------------------------------------------------------------------------- I...
Your timer is bad. It comes with 1 year limited warranty.
Buy one at Home Depot and then return defective one.
Make note of wiring before removing bad timer, so re-wire is easy.
GE 15086 is White 7-day digital, non-astronomic timer made by Tork, and sold on-line and at Home Depot.
On the shelf, 15086 timer looks identical to 15071 >> same package >>> difference is 15071 offers daylight savings time and random option, and costs a bit more.
These in-wall timers usually last a few years, and some can last for several years.
Especially when timer operates from electric circuit and not battery.
15086 operates from electric circuit.
15086 manual on-line:
Dec 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Need manual for a GE 15086 programmable timer
http://waterheatertimer.org/GE-15086-Manual.pdf
GE 15086 is a 7-day timer that lets you set 7 on-off programs on different days through the week
Suggestion that you make a chart of on-off times before programming since timer 'will not function as expected' if there is a conflict in programming
Oct 19, 2010 | GE Hardware & Accessories
Need instructions for a GE timer switch model 15086
Open link below to see wiring instructions and manual:
Jan 28, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Can GE Digital Timer model 15086 be used for two way switch?
GE 15086 can replace single pole switch only.
If you have "3-way" switch, that is when 2 switches control same light, for example in a hallway.
Open link below to identify GE15086 timer, see wiring instructions, on-line manual <> and see list of timers that can be used for 3-way switching with links to those timers and manuals:
Dec 20, 2009 | Hardware & Accessories
General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
635 people viewed this question
Top General Electric Hardware & Accessories Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
ray gallant
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
