Question about Sanyo DS31520 31" TV
Sirs: I have a new Sanyo 42" TV. We are on
Posted by herb_wilkins on
    Top Expert:
  • Sanyo Master
  • 76,713 Answers
Hello
If picture and sound is ok, and there is no colour, your push have sometimes made its system changed. I don't know from where you are, and to which country you belongs. Anyway I'll give you one solution.
Your Sanyo Tv may have multisystem compactable. There are mainly three systems in transmision of TV signals, called PAL [Phase Alternating Line], SECAM [Sequential colour and mamory] and NTSC [National Telivision System Committee]. Most of the europian countries have transmitters with SECAM and NTSC. I belongs to India, and here we have PAL BG system.
If the system has changed in the tv, the picture will not have chroma information, ie ,colour information, and black and white picture will be the result. You just do one thing. Just get into the Menu of your TV, according to its documantaion that you have, and go to the system menu, and make it "AUTO". This will solve your problem. Ok.
Posted on Nov 24, 2010
HOW DO I PROGRAM THE GE 24922 UNIVERSAL REMOTE TO THE SANYO 42" TV?
The manual you received with universal has clear instructions on what to do. Read it.
And if you have lost it, go to manufacturer of remote web site for a manual download.
Program direct tv remote o sanyo tv
press menu button, go down to parental,fav's & setup push select button,....go down to system setup push select button...go down to remote push select button...pick av1,av2,or tv press select button...pick tv press select...go down to sanyo and press select it will tell you what to do from there
3answers
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
I just bought a sanyo dp42841. I used to have the same tv in a smaller size. The first tv was hooked up to the cable and worked fine. When I attached the same cable to the new tv it's not able to find...
Be sure your cable is hooked up good and if you did not auto scan you must do this (auto scan) Found in the menu setup. Use the remote and press menu and it is usually found easily. Highlight the auto scan and start the scan usually by pressing volume +
We gave lost the remote for our Vizio 42" HDTV.
By manual I guess you mean the buttons on the TV and not switching the actual cables. my recommendation is to get a good new universal remote. My personal preference for my Vizio TV is the Logitech 650. Just know that you program it on a computer. It controls up to 6 devices (TV, DVD, Cable box, audio and more), is easy to program with no codes to enter. I am sure it is easier to get then a new Vizio remote though a little pricey at $60.
Hope this helps,
Cullen
8helpful
2answers
I recently purchased a "TDE SYSTEMS" jumbo
sanyo tv codes are 0506,0311,0612,0002,0428,0802,0412,0619 and emerson vcr are0626,0126,0826,0227,0327,0630,0632,0134,0037,0625,0924,0324,0128,0228,0428,0528,0447,0247,0724,0325,0526,0726,0027,0527,0827,0927,0628,0530,0830,0731,0634,0735
1helpful
Have a new Phillips 42" lcd tv. my cable box remote has been working intermittently. However the white light near the remote sensor on the TV blinks whenever I use the cable remote. after changing bat
your TV and, your cable box both "see" a series of invisible (infared) flashes of light like morse code these flases tell them what to do.one answer is to: buy a universal remote so that you can program a button for each device then when you want to control the cable box just push the "cable" button and, then volume etc. to turn your tv off push "tv" then "off" the service man was right but he should have explained this to you
also your cable remote may be programable to work with your tv like a universal remote check with your cable co.
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
2answers
Tv has no picture
sounds like a antenna block problem or a tuner?? Now Im wondering if this set has mutiple antenna inputs?? if it does then the antenna input switch is on the wrong mode.
Sanyo DS31520 31" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
