Question about Lanier VW-160T
I have a Lanier model VW 260 transcriber. 1) how do I erase old letters? and 2) does it have the auto rewind feature? (when I release the play pedal it goes back so many seconds) Thank you. Laura Boatright
Posted by lboatrigh246 on
Javier Gonzalez
  • 207 Answers
Hello Laura
Yes your unit has the option for erase Just hold down the REW and Telephone button at the same time make sure that you really want to erase the tape and the auto back space when you relase the foot pedal is the button located inside the front door they called Recall thats for adjusting how long you want to go back. thanks and good luck, if you ever need any type of accssesory please go to at www.tvps.com for large selection for professional Transcription units service and accessories http://www.tvps.com/Departments/Dictation-Accessories/Headsets/Cassette.aspx
Posted on Nov 25, 2010
Philips 720 transcription tape runs too fast
The deck is bad needs a new worm gear for the functioning motor.
Jan 22, 2014 | Philips PSP-LFH0720/52 Model 720 Analog...
How do I erase the tapes on a Lanier VW-210
Press the telephone button first with one finger and immediately after you press that button press the rewind button, The unit should go into rewind and erase should be flashing on the digital display. When the unit starts rewinding take your finger off of both buttons, if you keep them on ,then the unit will rewind and stop erasing .
Jan 13, 2012 | Lanier Audio Players & Recorders
Just started using Lanier model VW 260 transcriber for work. The counter display does not change. The top of the screen shows "Inst", "Length", "Unit No.", Total Units", and "Level". The only numbers it...
Hello the Display work like this insert the tape on the Lanier VW260 with the unit on rewind the tape to the end when you press play the Display start to count
Nov 13, 2009 | Lanier VW-160T
I have a dictaphone Smart 7120 and I can't get it
I've never encountered that problem, but the manual says: Make sure remote Transcribe indicator is extinguished. Move the Transcribe switch to Local position. Locate letter to erase with either [Prev. Ltr] or [Next Ltr]. Simultaneously press [Currnet Ltr] and [Erase] buttons to erase letter appearing in Item Status display. A tone plays and Erase LED lights briefly. Letter is automatically deleted.
To erase all Transcribed Letters: Make sure "In Use" Transcribe indicator is extinguished. Move Transcribe switch to Local position. Simultaneously press the [Finished Ltrs] and [Erase] buttons. Tone plays and Erase LED lights briefly. Good luck!
Do you know how to determine the total minutes on the machine? I have 2 that I want to sell, one of which is on eBay. Thanks.
Jul 09, 2009 | Dictaphone Office Equipment & Supplies
Lanier VW 210 transcriber beeps like it is at the end of the tape
There is a sensor that detects tape movement. Unfortunately they do go bad and will probably need to be replaced.
Nov 26, 2008 | Audio Players & Recorders
Lanier vw-210 dictaphone
It is not a problem at all! The VW-210 & 260 was designed to utilize a two-step erase procedure to prevent accidential erasing of tapes.
1.) Press & HOLD down the TEL button
2.) Immediately press & HOLD down Rewind button UNTIL erase function starts then quickly release both buttons.
Aug 05, 2008 | Audio Players & Recorders
Lanier Transcriber unit will not play
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
Mar 02, 2008 | Lanier 260T Desktop Cassette Voice...
Lanier VW-160T Logo
275 people viewed this question
Top Lanier Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
