You will need to check the voltage of the battery before and after charging , If the voltage is not coming up to 1.2V then the battery is defective. even if the voltage is present but does not drive the unit then the charge is not retained. If so the battery can be defective.
check the terminals of the charge for the charging voltage, use a Ammeter with a load to test the current. If these test prove good then the charger is working fine.
