Question about Canon PIXMA MP620 All-In-One InkJet Printer
Error code U052; keeps saying incorrect printhead installed - the printhead has never been changed
Posted by lboyd230 on
Anonymous
    New Friend:
Per Canon's website, and this just worked for my mp620:
Turn the printer on.
Open the cover.
Remove the ink cartridges.
Remove the printhead.
Re-install the above (this resets the printhead).
Close the cover.
Printer should initialize and go to home menu screen.
Posted on Dec 15, 2010
Brian Lee
    Scholar:
    New Friend:
  • 110 Answers
There's a defect in the printer. See
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Posted on Jun 24, 2015
Canon printer MG5250 not printing error code UO52 saying the type of print head is incorrect install the correct print head
This is a common Canon error (been going on for years)
see
http://community.usa.canon.com/t5/Printer-Multifunction-Support/Call-to-Arms-for-the-dreaded-U052-Wrong-Printhead-Error/td-p/65759
You can try removing all inks. Switch off and unplug from the wall.
Wait
Reinstall inks and switch on
(you may need to switch on first to align the print head) Switching off at the wall while the printheads are in view will leave them accessible.
Nov 27, 2016 | Canon MG5250 Printer
Canon Mp550 error after i cleaned the print head with soft dry tissues and re install it .U052 the type of print head is incorrect.
A common experience among users of various Canon inkjet printers. The lawsuit settlement is close to being finalized so join soon.
Dec 27, 2014 | Canon Office Equipment & Supplies
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the...
u Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My canon MP610 shows an error message U052 Incorrect print head
Sounds like you have to buy new printhead... take a look on amazon: Amazon com canon mp610 printhead. I hope this was helpful. Cheers
Mar 01, 2010 | Canon MP610 Photo All-In-One Printer
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error message u052
That is a printhead error, sounds like you will need that new printhead.
Aug 12, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Code U052
Dear dgthorpe,
This indicates that printhead of your printer faulty. Commonly this problem come with short circuitry problem in printhead so it may harm logic board and carriage unit too. I suggest you to try checking with another printhead first.
Regards,
Oct 10, 2008 | Canon MP970 Photo All-In-One InkJet...
I have just re-started my Canon PIXMA MP610 after it has been in storage for 2 months. It is around 1yr old. It seemed to work OK. When i went to print the 1st page, the paper jammed because of some...
I would suggest removing the printhead, make sure there are no more dead roach's under the printhead, also make sure all lights on the ink tanks are lite up, the first error code you mentioned has to do with the ink tanks, the second one has to do with the printhead. I would suggest un-installing the printhead, then reinstalling it doing the alignment, and that should clear the error code.
Sep 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
Jul 26, 2008 | Office Equipment & Supplies
Canon PIXMA MP620 All-In-One InkJet Printer Logo
4,098 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
