Motorola Mobility Boost Mobile Nextel I215 I415 I450 Battery Logo
Anonymous Posted on Nov 24, 2010
Took my boost mobile sims card out of nextal/motorola i was useing and put it into my boost phone,can't receive texts messages or phone calls
Anonymous
Level 3:
  • Motorola Mob... Master 32,281 Answers
  • Posted on Nov 24, 2010
Anonymous
Level 3:
Answers
32281
Questions
Helped
7912712
Points
102259
To get the security code/restriction code to unlock thecell phone from the current cell phone provider so you can use it with adifferent phone provider, Please click on this link and follow my instructions:- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then this WEB siteit provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw Try this WEB site also - UnlockFree http://www.unlock-free.com
I cant get my motorola w510 to send a text message
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Text messages gone
When you take your battery out of your phone it automatically erases call log/sms etc unless you have saved them in a save folder.
1helpful
Put nextal sim card in i290 phone 'boost' and now says please whait to enter special code
although boost is a ppd version of nextel, the sims cards are different and are not interchangeable between devices........you can contact SprintNextel and they will give you the "subsidy unlock" code, which is the special code required for your device to stop looking for a specific sim card. If they wont give you the code then you can google "motorola instant unlock" or whatever brand device it is and chose from the large list of web services that can send you the key for just a few dollars. GOOD LUCK AND PLS RATE THIS POST!!!!!!!
How can you use a blackberry nextel phone with your boost plan
You do not need to "unlock" that blackberry.  If you put your boost sim in it the phone calling and direct connect will work immediately.  Getting the txting and internet to work require you to install other service books.  Try this link http://www.howardforums.com/showthread.php?t=1530734  which explains how to remove the old books and add the correct service book to use mms and internet.
I brought a ic902 at a auction and i have a boost mobile. the phone works ok. But when i put my sim card in it, the phone reads invalid sim, put old sim back in. what can i do to use my sim with this phone
>>Expert
>>Motorola Phones
>>Boost Mobile
I activate phones for Boost Mobile.
I'm sorry to tell you, but an ic902 can never be unlocked to work properly on any other system - to include the Boost system. Here's why. The ic902 is a hybrid phone. That is, it uses two different cellular systems to operate. Specifically, voice calls on the ic902 are placed over the Sprint CDMA network and Push-to-Talk (PTT) calls are transmitted over Nextel's iDEN network.
Boost Mobile calling (both, voice and PTT) uses the iDEN network from Nextel. Thus, the ic902's radio transmitter (which is CDMA) cannot make calls on the Boost ( iDEN ) system.
Moreover, if you plan to use Boost Mobile, I STRONGLY suggest that you NOT purchase a Nextel phone and have it unlocked to use for Boost.
Although Nextel and Boost phones seem the same - they are not. If you look at the model number of Nextel phones most of them end in a zero. (ie., i850, i870 etc.) where Boost Mobile Phones end with the number five. (ie., i855, i875, etc.) This is because the transmitters in the phones are set to different frequencies for different purposes (like for texting.)
If you go to eBay for example, those who sell unlocked Nextel phones to use for Boost (if they're honest) will inform potential buyers in their eBay listings that their unlocked Nextel phone will not (text, for example) on the Boost network. These unlocked Nextel phones will have limitations when used on Boost.
To prevent problems down the road, ALWAYS purchase a Boost phone to use on the Boost network.
If this information has been helpful, please give me a big thumbs up when you rate my answer.
Retrieve 'bumped out 'message from phone
I am going to have to side on the No side. Some phones have a small limited memory to store these messages, so when that space runs out, the system removes the last text to make room for new ones. I had a friend with a Moto Q on Verizon (CDMA = No SIM) and it was her biggest complaint.
My advice is to erase all the messages you dont want as you get them in, that way this wont happen.
Also, backup the phone, you can find the utilities online. Verizon does offer a backup service in their cloud for your address book. I know you use Boost, which is owned by Sprint (not verizon as you indicated). Boost uses the Nextel technology of Sprint which is iDen. That is closely related to GSM.
Net net...call your service provider that is your only option. I am sorry.
2helpful
I put a boost chip in my ic902 and its says please insert right sim. sim doesnt match stored accnt info..does anyone know what to do? i really want this to work..please help! im ignorant on this subject.....
>>>>Expert
>>>>Motorola Phones
>>>>Boost Mobile
2answers
I855 text messaging
If this your motorola i855e is a Nextel phone, then not all the features will work very well if you put in a Boost Mobile sim card. Features like Texting, Web browsing are not likely to function very well or at all. Get a Boost phone for a Boost sim card. Cheers.
1helpful
Need Boost SIM card to work in Nextel Motorola Buzz+ ic602 phone.
I called Boost support about the same issue and I was told that that particular phone and any other Ic series phone by motorola will not work with Boost Mobile. There was also a few other phones that will not work. Try calling thier support line and requesting the list of phones that won't work. Good luck.
1helpful
5answers
Motorola i930-no texting-originally Nextel-now boost
I had the same problem but I have nextel. I called them and they just told me to send all text messages as 'MEDIA MESSAGES' and it works!
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
