Question about Janome Memory Craft 5700
HOW DO I ATTACH PRESSER FOOT G TO MY MACHINE??
Posted by diane_doughe on
Debbi's Sewing Machine Repair
  • Janome Master
  • 7,365 Answers
There are 2 type of presser bar foot clamps
one allows you to snap on the foot--raise & then lower the presser foot holder until the cut out is directly above the pin on the foot,,as you lower the presser foot holder the presser foot will automatically engage when put down on the pin area
the second is a shank & foot combined & there is a screw on the presser bar,,unscrew it some & put the shank up around the screw & retighten the screw
Posted on Nov 24, 2010
5 Related Answers
Anonymous
  • 65 Answers
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
Posted on Jan 05, 2009
Anonymous
  • 24 Answers
SOURCE: Can I loosen the presser foot so knits will not stretch
Pressure on the pressure foot can be adjusted on some machines by turning the knob on the top leftside of the machine directly above the needle assembly. Look for a knob that has fabric types on it and adjust accordingly. Also check your thread tensions.
Posted on Feb 09, 2009
Anonymous
  • 37 Answers
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Posted on Apr 16, 2009
ken dourof
  • 980 Answers
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Posted on Nov 04, 2009
Anonymous
SOURCE: The presser foot lifter of my Singer 9432 has disconnected
Had the same problem.
Open the cover where the light bulb is.
Follow the presser foot rod up into the machine.
You will find a metal keeper with a set screw facing the now open end of the machine.
That set screw has most likely come loose.
Since the presser foot is spring loaded to the down position leave the presser foot raising lever in the down position.
With your flat bladed screwdriver, gently push the metal keeper to it's lowest position. If it does not go easy, loosen the metal keeper set screw a bit. Lefty loosey.
Tighten the set screw on the metal keeper. Righty tighty.
Posted on Jan 03, 2010
Cant get the bernina walking foot in position on the 1031 machine
The walking foot has a spring loaded lever that rides on the needle clamp screw. If you lower the needle into the hole on the walking foot it will remove the pressure and make it easier to attach the walking foot to the ankle.
Mar 07, 2016 | Bernina Sewing Machines
How can I attach a zipper foot to my unidentified machine?
Assuming you have the correct zipper foot attachment for your machine, you should be able to attach it like any other presser foot. On some machines, you may need to adjust the needle position to the right or left so the needle will not hit the presser foot when stitching.
Feb 10, 2016 | Sewing Machines
I have a Sears Kenmore sewing machine I want to get a 1/4 in presser foot for it, is there one and where would I get it/
You first need to determine which shank the presser foot uses on your machine. You can compare your shank (current presser foot) with these photos to see which one your machine uses.
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
NOTE: If you purchase a snap-on presser foot, you will also have to buy a "shank adapter" that will attach the presser foot to the needlebar. Here are some pictures of snap-on adapters:
Kenmore sewing machine snap on adapter Google Search
However, you will still need to make sure to buy the correct adapter for your machine. The GREAT thing about buying a snap-on adapter is you can add a lot of presser feet to your sewing machine accessories because you can purchase additional snap-on presser feet or even a complete set of snap-on feet that will all work with your adapter and your machine!!!
Kenmore Presser Feet eBay
You will just snap one foot off and snap another on!!! Great idea!!!
OR--you can take your current presser foot along with the make & model of your machine and check with the local sewing repair shops to see if they have what you need.
FYI, once you know what shank your machine has, you can probably also find other specialty feet for your machine, ie walking foot, free-motion foot, etc.
Jan 17, 2016 | Kenmore Sewing Machines
Quilting and patchwork foot with attached shank
Probably, but since we don't know the model, we can't help you much.
You can search the internet for your make and model machine and search for a 1/4" presser foot. You'll most likely find one piece presser feet or even snap-on feet where you purchase the shank adapter and then separate presser feet that attach to the shank.
You can also check with your local Pfaff dealer.
Nov 08, 2015 | PfaFF Sewing Machines
How to attach free motion foot
Most free motion feet attach like the other feet.
It is creating "thread nesting" also called birdnesting. Could be several things:
1) make sure before you thread the upper thread, RAISE the presser foot so the thread will seat properly in the tension disks
2) drop your feed dogs before you begin to free motion
3) your free motion quilt foot, when lowered, should not rest on the fabric. (Be sure you are lowering your presser foot when you want to stitch!) You should be able to move the quilt sandwich easily under the presser foot. If the foot applies any pressure to the fabric, you may need to release the presser foot pressure (consult your manual). Or you are using the incorrect presser foot for your machine.
4) If none of the above, you need to tighten the upper tension AND
try this method before beginning to free motion stitch:
How and Why to Bring up the Bobbin Thread
Aug 09, 2015 | Sewing Machines
Why can't I get my presser foot to attach
could be the wrong size pressure foot for your machine.
Sep 01, 2014 | PfaFF Sewing Machines
Bar that hold the sewing foot is loose
If the comment already posted did not answer your question, here is another thing to check. If the screw that attaches the foot and ankle to the presser foot bar is tight, and the foot can still be moved, it is likely that the presser foot bar has become loose within the lifting mechanism. You could save yourself some trouble by taking your machine to a sewing machine repair shop, but if you would rather avoid that expense, do the following. Remove the needle bar and take up mechanism cover on the left side of the machine. This is held on by a single phillips head screw on the back side of the machine, which, with the back of the machine facing you, should be on the top right side of the machine. Once this cover is removed you will be able to see two vertical metal shafts, one is attached to your needle clamp and needle, and should be in the front. The other is the presser foot bar, and will be behind the needle bar. There should be a small allen screw about halfway up that shaft that tightens onto the bar. With the presser foot properly positioned on the needle plate, tighten this allen screw. Don't tighten the screw too tightly, as this can damage the presser bar, just make sure it's nice and snug. Make sure the presser foot raises and lowers properly, and re-attach the needle bar cover.
Hope this helps.
Mar 16, 2014 | Brother CS6000i Computerized Sewing...
Where can i buy presser foot for futrura ce 100? is it low shank? can distinctive presser foot be used?
You shouldn't need a specific CE100 presser foot. A universal presser foot that will attach with a side screw will work fine. I use standard zipper foot and other standard feet on my CE100 all the time.
If you don't know what a "universal" foot is, ask for help at your local Joann's or Hancock Fabrics, or whatever store you go to. Or do a search online for a Universal presser foot and examine it. It should have a spot on the lefthand side of the shank that the screw will slip into either from the top, behind or front to attach it to the shaft coming down from the machine. No need to purchase a special foot at all.
Mar 04, 2011 | Singer CE-100 Futura Computerized Sewing...
I cant figure out how to install the buttonhole foot
Do you just need to attach it to the machine? Or are you having trouble using the foot itself?
It attaches the same way the other feet attach. Remove any foot that may still be attached to the machine. On the buttonhole foot look for the small silver pin that sits on the sliding piece with the small red line marks on it. Lift up your presser foot lever and attach the buttonhole foot's silver pin the same way you would attach any other foot.
As far as using the foot itself place your button on the back sliding piece snuggly till it fits in without falling out, adjust as needed. Pull the bottonhole lever down (it's located on the machine opposite the side of the presser foot lever) so that it rests behind the first lever on the buttonhole foot (small plastic piece raised on the left hand side of the foot that doesn't move). Slide the feed dog switch on the back of your machine so the feed dogs go down. Select your stitch and go. The machine automatically stops when done.
Hope this helps!
Feb 11, 2011 | Brother CS6000i Computerized Sewing...
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
Sewing Machines Logo
522 people viewed this question
Top Janome Sewing Machines Experts
tina gallow
Lee Hodgson
Lee Hodgson
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
