Question about Mag Innovision LT782S 17" Flat Panel LCD Monitor
What does the power cord look like and where does it go on a model 780. It is my older monitor ( about 6 years old) and I want to hook up my old Alienware Computer for my husband while his is at the doctor's Do I have to remove the stand to plug in the power cord and if so how do I remove it. It has been a while since I hookid uyp the older monitor and computer.
Posted by lkarrol on
5 Related Answers
Anonymous
  • 198 Answers
SOURCE: Sound for a Mag Model 780 Flat screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Anonymous
  • 198 Answers
SOURCE: Mag Innovision LT776s Model 780
Good Luck!
Anonymous
  • 198 Answers
SOURCE: MAG INNOVISION
Good Luck!
Anonymous
SOURCE: What is needed to hook up monitor
i HAVE THE MONITOR CORD FOR THE MONITOR, BUT NO POWER CORD.WHERE CAN I BUY A POWER CORD FOR A 2002 MAG INNOVISION.
Posted on Dec 12, 2008
ElDopa
ElDopa
  • 295 Answers
SOURCE: Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Posted on Aug 23, 2009
2answers
Monitor not waking up
dont know how old monitor is but it may be time for an upgrade OR the pc/laptop/desktop? may need some setting changes for your wake time, sleep time, intervals, etc.? Sometimes if laptop,, you have to tap the power button to wake up after extended sleep times.
1helpful
Where do i get a power cord for a proview monitor? Model: 780 Date: 2001 Product #: pl 765. 12vdc 5A. On the front the brand name that is on it is proview. That's it.
Hello there:
Almost any monitor or computer power cord can be purchased at a electronics store like walmart or staples or even a second hand store like goodwill that is where i get all of my spare cords for the computer repair buisness that i have and i only pay about 3 dollars or less for them most monitor cords are compatable with any computer unless it is a special brand ok I hope this helps you out
Best regards Michael
2helpful
2answers
MAG 780 Innovations LCD Monitor
The plug end (to the monitor) is a partial square end with three top angles. That plugs into the back of the monitor. You can see the plug socket from the underside.
1helpful
Kds model 780 monitor no signal, power button does not work
My monitor does the same thing at times and sometimes shows "No Signal" and at other times the screen will maintain the images but the backgound color switches to mustard yellow. In each of these cases I have been able to solve the problem by unplugging the power cord from the electical outlet for about three seconds and plugging it back in. I have a KDS model 780 LCD.
GOOD LUCK
Good Luck!
Mag Innovision LT782S 17" Flat Panel LCD Monitor Logo
Top Mag Innovision Computers & Internet Experts
Ekse
Mandeep  Singh
Mandeep Singh
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
