To give you the right information, brand and model is needed. also if its electrical plus gas, or just electrical...Now if you get power to the clock usually the clock works all the time.. if you have knowledge with a voltage meter I sujest you test the main power to the main device. in some cases there is a fuse of somekind. you must test for continuaty. test for power to the knobs and when you open the know you should have power on the continuing wire. test the knob from one end to the other for continuity by turning clockwise and counter clockwise. if there is continuity you know it works fine. then test for main power. test for continuity, then test for main device power.consult a voltage meter instructions if you dont know how to do it.
TEST FROM THE BEGINNING TO THE MAIN STOVE. THE BURNERS ALSO HAVE ELECTRICAL CONNECTIONS THAT OFTEN GO BAD BECAUCE OF THE HEAT THEY ARE ALWAYS EXPOSED TO. I JUST REPLACED SOME OF THEM ON A STOVE. FOR THE SAME REASON AND WITH THE SAME PROBLEM. IF YOU PROVIDE AN EMAIL ADDRESS I WILL EMAIL YOU THE DIAGRAM WITH INSTRUCTIONS ON WHAT TO TEST FOR AND HOW TO TEST IT. YOU WILL SURELY FIX YOUR PROBLEM. MINE IS [email protected]
IT SEEMS LIKE IT IS YOUR CONNECTIONS TO THE BURNER.. IF ITS ELECTRICAL
The brand and model is Frigidaire FEF357B Freestanding Electric Range and the part # is 316259186. I can't find any fuses but the buzz is coming from the board and it just does it for a split second when I turn the knob to turn on a burner. If I turn on the burner the oven settings work on the display but the oven itself won't heat.
Is that the information you are needing? Thanks for your help!
I sent you an email. If you didn't get it just let me know. Thanks
Thanks for your help. I found it, whoever installed it did not tighten the wires coming from the plug and because of that it burned one of them out.
