Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
On my Sony KP-65WS510 The colors are misaligned in the picture and the picture is bowed. Any ideas? Thanks!
Posted by drider709 on
Anonymous
  • 10,594 Answers
This problem appears due to convergence output ICs failure located on D board in tv. There are two big black ICs that need to be replaced, soldering work is required.
Let me know are you handy with electronics stuff repair and can replace parts in circuit board to provide you more technical info OR local tv repairman will do this job for you.
Thanks.
Posted on Nov 23, 2010
Convergence does not work. Black spot in corner of picture
Convergence will not cause the black spot--picture will look 3d or colors skewed, confirm model please and a clear idea of what set is doing or not.
Possible Lamp Sensor Problem
Google the model number for six blinks for that is an error code---this set uses no lamp---it has 3 picture tubes
1helpful
I have sony KP-65WS510 TV, started reporting convergence problem and showing pictures 3 different color. After I talk to Sony Technical Support turn OFF and ON method for initial trouble shooting.Now TV...
Tv have convergence problems first,fix the convergence board first.The tv have mis R,G,B colors lines alignment have 3D pictures effect.The tv convergence board have totoal dead 2 ICS convergence ICS and some or all it resistors.U know how to do basic's soldering?U have tools like a soldering iron,desoldering pump or solder witch and solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy ur tv make and model of convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.Now,the projection lamp, might need to replaced too,after fixing the convergence problems.
Misaligned convergence on sony kp-65ws510
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
Sony KP-57WV600 different colored images red,
Ur convergence is dying,well be dead soon.These problems cause byconvergence.Blurry coloring,3D images or misaligns colors.Repair this must replaced 2 convergence ICS and all it resistors.The shop well cost U 300 for parts and labors.
2answers
What would you pay for a 2004 Sony 65'' hdtv model
Yes,if power it stable,have picture,(not light or dark pic mean the tube it dead). Bad picture it ok it can be repair.New one 1300 buck.
14helpful
Sony KP-65WS510 Convergence Problem
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
1helpful
Convergence problem?
Screen looks 3D
>>>Solution<<<<
I have a convergence problem. My Sony KP-65WS510 has a picture that looks like 3-D and bows at the bottom and top of the screen. I already replaced both the IC's STK 392-560 (2 qty.) and check all six 3.5a...
Screen looks 3D
>>>Solution<<<<
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
