SOURCE: I need a manual for a Kitchenaid Food Processor Model #KFP600WH
The Kitchenaid website doesn't recognize the model number you gave. Could it possibly be KFP760? If so, then here's a link to the free downloadable manual.
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KFPW760OB_Use%20and%20Care.pdf
SOURCE: need a replacement part for food processor
The motor is runing, but the blade is not turning.
SOURCE: I need a replacement bowl for the Oster 3212 Food Processor
I contacted the manufacturer and bought the bowl. This is frustrating as I had contacted their authorized service center and was told the bowl was unavailable.
SOURCE: my kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
