Question about Whirlpool Washing Machines
MY WASHER FILLS WASHES, BUT WONT DRAIN OR SPIN, AND I DONT HEAR A HUMMING NOISE
Posted by selvynstubbs on
Anonymous
    New Friend:
    Problem Solver:
  • 7 Answers
As you mention not hearing a humming noise usually means there is no power to the motor assembly. A very common cause of this is a defective lid switch.
Open the machines lid or door press the striker pad and listen for a clicking sound. Or open and close the lid/door gently listening for the same sound, the switch to engage.
You'll probably find thats your problem.
Take care
Posted on Nov 23, 2010
Washes then does not empty and spin
It has to drain first before it can spin. Put it on final spin & press start. If you can hear a humming noise that will be the drain pump trying to go. It will have a blockage.
Apr 02, 2016 | Fisher and Paykel Washing Machines
It fills up..washes..but wont drain or spin out..
I had the same problem. Checked the pump and it ran fine. Took off the door locking mechanism and put 120 ohms into the wax motor part and it tested fine too. I read about problems with that wax motor so I replaced the complete door switch today for $71.00 and the washer runs perfectly now. If it won't spin or even fully drain I suggest replacing the door switch.
Jul 14, 2009 | Washing Machines
Washer fills and washes ,stops but will not advance to spin cycle
if washer will not drain or spin !! , try this solution , 1 ) open washer and at the bottom locate a small DRAIN MOTOR PUMP , is usually clogged with lint & debri , take it out , clean it , replace and try again , let me know , AJ
May 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
Wont drain or spin
Check your lid switch it's probably broken.
Jul 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Washer help
Check the lid switch. Some units use a safety lock out. If it is not working then the unit will not drain or spin.
Nov 13, 2007 | Frigidaire FEX831CS Top Load Stacked...
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
