Laser Hair Removal is a procedure to get rid of unwanted hair from your any of the body part. It works for almost any skin type. With latest advancements, it is considered a safe and effective treatment if you unlike shaving, waxing, or epilating etc. It has become the widely used treatment lately which can save you from irritating shaves or even burns.
It will take the entire series of treatments, and that number depends on the dermatologist.
Laser hair removal is a procedure by which hair is removed from the body by utilizing a long pulse laser. Lasers are developed and designed from years of research. The laser parameters are carefully defined by studying the anatomy of the hair follicle and precisely matching the laser light and pulse duration to the follicle size, depth and location to inhibit the re-growth of the hair.
Laser hair removal is performed by a specially-trained laser specialist or a doctor depending on where you go, who distributes the light of a long pulse laser onto the skin. The laser works by disabling hairs that are in their active growth cycle at the time of treatment. Since other hairs will enter their growth cycle at different times, several treatments are necessary to disable all of the follicles in a given area.
As the hair on the bikini line is so thick - I think waxing is the best option. With waxing, the hair is pulled out from the root and over time it grows back thinner.
Laser hair
removal works by shooting a light onto your skin. It focuses on the melanin
that gives the hair its color. This
causes the follicle to die and then the hair falls out and then doesn't
re-grow.
It can take several treatments to start seeing results so it's not a cheap option but many people use It to try and get rid of their back hair.
