Question about Bugaboo Cameleon Jogger
I cant fold my bugaboo cameleon chasis. how can i open the silver cap on the side to take it apart?
    Guru:
  • 541 Answers
I answered a similar question only yesterday. The sliver cap is a Capped Starlock do a google to find out more. They are a one use item and trying to remove them for reuse will mark the plastic hubs and make a weak repair. Here's my How to fix a Bugaboo Handle instructions
If you are not a handyperson type, take these instructions to you local Bicycle Mechanic or Small engineering shop.
The bugaboo handle fault is caused either by two small plastic pins shearing of a plastic disk that actuates two metal locking rods or a broken locking rod. Why bugaboo uses plastic for the disk and aluminum for the locking rods is beyond me! They are critical components with a history of failing!
1/. Remove the capped star lock washer. This is the hardest part of the job. Most people try to leaver this off in the hope of re using. First problem with this is you will mark or damage the surrounding plastic second is star locks are not intended for reuse and will never hold as well as when first used, so best find a new replacement. A hardware store should be able to source some for you. Quickest way to remove a capped washer is to carefully cut a slot in the dome with an angle grinder and then use a large screwdriver to carefully prize one side up so you can fit a screwdriver. Note the walls of the aluminum hub axel are thin and easily distorted, make sure you only lever the capped star lock and not hub axel. Use one screwdriver as a support and another to lift off the capped star lock.
Note it is best to open and repair one side at a time, so your moving and flexing one side of the handle does not dislodge parts in the other side. The hub and disks are mirrors of each other and not interchangeable. The side with the brake lever is left The Bugaboo parts will have an "L" after their serial numbers.
2/. The lock mechanism is very simple; a wire rod rotates a plastic disk. Check the hubs for ware. If too badly worn or damaged you will have too much movement in the locked position. The Frog and Chameleon use the same plastic hub find another frame to salvage hubs from. They are held in by a single aluminum rivet.
The disk has two plastic pins that move the locking rods in and out of the inner hub into and out of the outer hub. You need to either repair the disk by drilling out the pin stumps and finding a replacement metal screw you can fit / glue in. Or (my preferred choice) have a new metal disk fabricated that will last a lifetime.
I cant fold my bugaboo cameleon chasis. how can i - macnutz_21.jpg"/uploads/images/macnutz_21.jpg" alt="macnutz_21.jpg" class="h_mi" />
3/. Reassemble handle locking hub and check operation. If wire rods seem to be in the incorrect position, loosen the top plastic fittings where the handle extends from by removing the small self-tapping screws and wiggle things into alignment. (I use a small amount of the grease used for taps to give a smooth action) If all is working well fit the new capped star lock on the hub shaft and tap home. To protect the dome finish I use a large socket from my socket set and an old rubber washer from a toilet cistern.I cant fold my bugaboo cameleon chasis. how can i - macnutz_22.jpgt operation on the other side
I have parts available laser cut metal disks with stainless steel pins, replacement locking rods in stainless steel and capped star lock washers you can contact me at [email protected]
Regards
Steve
Posted on Nov 23, 2010
Help! I folded up my stroller base, and now I cant get it to release and open!
Click on my name and check out my tips section try lubrication as explained in the How to.
Feb 19, 2011 | Bugaboo Cameleon Jogger
Hi I have a bugaboo camealeon but it needs tightening up, I think it's were the silver caps are?? If so how do you take the off? Please help
hi
i would advise against you doing this yourself as they are starlock caps and are easily damaged
but instead of taking them off maybe you could try tapping them lightly a few times you may have to use
something over them.
other than that i sugeest you contact bugaboo or the local bugaboo dealer
Oct 19, 2010 | Bugaboo Cameleon Stroller
I've been having intermittent problems with my Bugaboo Cameleon's chassis. When folded up and trying to unfold, one side often became stuck and took patience and gentle coaxing to finally open both sides...
BUGABBO BEE HANDLE PROBLEM!
I've problem with my bee !
The handle just slide down without cliping The locks SO IT'S IMPOSIBLE TO PUSH THE BEE AS THE HANDLE is moving all the time????what can do?please help
Sep 08, 2010 | Bugaboo Cameleon Jogger
Bugaboo Cameleon silver button holding together chassis
yes i have the same problem it has snapped, i would be grateful for someones help on a replacement.
Aug 27, 2009 | Bugaboo Cameleon Jogger
Faulty Latching Mechanism On Bugaboo Cameleon
SOUNDS LIKE THE SPRING NEEDS REPLACING... INSIDE THE HANDLEBAR ARMS SHOULD BE A CROSSHEAD SCREW... UNSCREW THIS AND PULL THE HANDLEBAR OUT, THEN SEE IF THE SPRING IS BROKE OR MISSING AND REPLACE IT :)
HOPE THIS HELPS X
Apr 17, 2009 | Bugaboo Cameleon Jogger
Cant fold the chasis
send it back to Bugaboo for a replacement. Assuming it is under two years old
Apr 16, 2009 | Bugaboo Cameleon Stroller
Bugaboo cameleon problem
call bugaboo depends what it is sometimes it can be fixed
Tel # 1-800-460-2922
Sep 12, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Jogger Logo
1,889 people viewed this question
Top Bugaboo Baby Gear Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
