Remove the front panel and tape down the door safety switch so the unit can turn on when door is off. Turn up thermostat to make sure there is a call for heat. The circuit board should indicate a call for heat with either a blinking light or a solid light. Then the exhaust fan should turn on clearing the venting from any fumes. When the fan has ran for a few seconds, the igniter should start glowing orange. After it reaches a predetermined temperature, the gas valve should open with a click. The flame will start at the burner closest to the igniter and travel away from the igniter. There is a small flame rod located in the flame path on the last burner that tells the circuit board it feels the flame. If the flame goes off within a few seconds of starting, you have a dirty flame rod. Clean it with a scotch-brite pad. Once you get the flame to stay on for 90 seconds or so, the room air blower will turn on. If it tries 2 or 3 times to start but does not, the circuit board will record a code and display it with a blinking light. Look on the door panel for a wiring diagram. There will also be a Diagnostic chart that will tell you what the pattern of blinking lights represent.
Good Luck!
I had a similar problem, but it turned out to be a pressure switch (that was 13 years old)... they can wear out and tear, causing similar symptoms... check out this blog for more details:http://gasfurnacepressureswitch.blogspot...
