Question about NEC MobilePro P300 Pocket PC
I have an nec mobilepro p300 and the sd card stopped working . the ppc no longer "sees" the sd card and says it is un-installed and I can't figure out how to reinstall it . So far the internet is no help.
  • 229 Answers
Check out the settings
Posted on Nov 23, 2010
Testimonial: "I checked the settings. There is no way to install the sd card from there."
6ya staff
SOURCE:
Why won't my p300 read my sd card?
Hi
What is the memory capacity of the card? if its more than the required sd card memory capacity compatible for the phone it may not read it. normally this phone supports up to 1gb sd card
May 10, 2009 | NEC MobilePro P300 Pocket PC
Not recognize the PC Card Expansion Jacket after a soft reset
Make sure the P300 has completed the boot process before attaching the PC Card Expansion Jacket. This will ensure proper detection.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
My P300 won't sync when it is attached to the PC Card Expansion Jacket and inserted into the USB Cradle?
You can prevent this issue by making sure the P300 is turned on before putting it in the cradle. This is limitation of the current operating system.
SD is slower
SD is approximately 1/2 the speed of CF, but the benefit is that SD uses almost 1/2 the power consumption of a CF card. Additionally, it leaves the CF slot available for different I/O cards.
How many recharges can it take?
The MobilePro P300 can be recharged hundreds of times, which is estimated to be equivalent to nearly 3 years of consistent use.
Failed to recharge the main battery before it is completely drained
You can avoid having to completely re-set your personal settings by using the back-up utility pre-installed on your MobilePro P300. To do so, tap Start --> Programs --> My Settings and tap Backup Utility and follow directions to back-up personal settings onto a SD or CF card. You may also use your desktop Microsoft ActiveSync software to save your MobilePro P300 personal settings onto your PC. To do this you open the ActiveSync window on your desktop and go to Tools --> Backup/Restore and follow instructions.
Methods of extending the battery time
Decrease the Front Light brightness while the MobilePro P300 is on battery power. To do so, tap Start --> Programs --> My Settings and tap the Front Light icon. Click the "DC" tab and decrease the brightness level to the desired level.
Disable the record button
Tap Start --> Programs --> My Settings, tap Wakeup Icon, remove the check mark from "Recorder Button", and tap "OK". The record button will not work when the MobilePro P300 is off.
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
NEC MobilePro P300 Pocket PC Logo
93 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
