THE ORIGINAL code set to the phone by the MANUFACTURER IS: 1234 OR 0000
Type the code 1234 into your phone. If you have CHANGED this code to a PERSONALIZED CODE and you have FORGOTTEN the code, there are TWO SOLUTIONS FOR THIS MATTER:
1.) dial as follows: *2767*3855#
THE PHONE LOCK CODE WILL BE RESET TO: 0000
SECOND SOLUTION: dial as follows: *2767*2878#
THIS SHOULD SET THE PHONE LOCK CODE TO 0000
If you have recently purchased this device and have not set a PERSONAL SECURITY CODE, Generally the ORIGINAL code will be the LAST 4 DIGITS OF YOUR CELL PHONE NUMBER. EXAMPLE: if your number is 555-3765, then your pass code will be 3765. You may also try the basics such asl 1234, 0000, 4321, 5555, or even the LAST 4 DIGITS OF YOUR PHONE. It might possibly be the last 4 digits of the device SERIAL NUMBER.
pls give sir
