Mitsubishi WS-55809 55" Rear Projection Television Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Distorted picture after moving across town - Mitsubishi WS-55809 55" Rear Projection Television
Shawn O'Halloran
Level 2:
  • Expert 345 Answers
  • Posted on Nov 23, 2010
Shawn O'Halloran
Expert
Level 2:
Answers
345
Questions
0
Helped
97438
Points
966
You may have knocked your guns out of alignment. There should be calibration settings in the main menu. Can you post a picture of the display so we can see what you mean by "distorted."
1helpful
Lines and distortion across screen
Check and replace the smoothing capacitor used at it video output voltage This capacitor can be located at the neck board of picture tube.To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
1helpful
2answers
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Is my picture tube going?
Hi there yes this is a common problem with old tube tv's and yes eventually stuff seems to break down there is not alot you can really do about it to be honest ...my suggestion is that this is lifes way of saying upgrade ...this tv has done well ....if your looking to upgrade i would suggest going to a Samsung LA26C450 as a replacement television or if you are not so much a fan then a KLV26BX300 as a new option ,
Cheers
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Can't see picture
Is the onscreen menu just as distorted and are the lines across it or behind it? The pop you heard may have been a capacitor and since the TV is still powering on, it's the probably the video controller board that is on it's way out. If the onscreen menu looks fine, you maybe having a problem with the input board only so try a DVD that uses a different input and if it's poor, I would say the TV needs to have the input/output board service. If the OSD is distorted as well then it's definitely the video controller board and service is likely required.
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
2helpful
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Horrible picture after moving
Sounds like your convergence chip has gone bad.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
