Texas Instruments TI-83 Plus Calculator Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The square root of -(49/64) - Texas Instruments TI-83 Plus Calculator
k24674
Level 3:
  • Texas Instru... Master 8,093 Answers
  • Posted on Nov 26, 2010
k24674
Level 3:
Answers
8093
Questions
0
Helped
4675358
Points
21596
The square root of a negative number does not exist in lR, the set of real numbers.
In the set of Complex numbers the square root of -49/64 is (7/8)i, where i is the imaginary unit defined by i^2=-1.
2answers
How to calculate the square root
The square root is the second function of the "3" key. To calculate the square root of 3, press 3 2ndF 3 =
1helpful
4 squre root 81
Take the fourth root. The square root, denoted by a 2 on top of the "root thing" or more commonly without a number at all, is the second root.
Usually the easiest way to calculate the fourth root is to calculate the square root of the square root. So in this case the fourth root of 81 is the square root of the square root of 81. The square root of 81 is 9, the square root of 9 is 3.
2answers
What Has The Same Value As Square Root Of 7 Multiply By Square Root Of 15
(Square root(7))*(Square root (15))=(Square root (7*15)=Square root(105)
3helpful
Have TI30xIIS calculator. How do I find square root of a number. For example, the square root of 9. Where is the square root? I know 3 is the square root of 9, but how do I do this on calculator. ...
To calculate the square root of 9, press
2nd [square-root] 9 ) =
The square-root is the shifted function of the x-squared key, just to the left of the 7 key. The close-parenthesis is needed to balance the open-parenthesis automatically inserted by the square-root function.
How do a take a division problem and square root it on a TI-84 Plus Silver Edition for example 87.34/5 then square root the answer. I can do the math, but how do I take the dvision answer and square...
Two ways:
2ND [square-root] ( 8 7 . 3 4 / 5 ) ENTER
8 7 . 3 4 / 5 ENTER then 2ND [square-root] 2ND ANS ENTER
The first sequence takes the square root of 87.34/5, the second sequence calculates 87.34/5 then takes the square root of the result.
5helpful
Were is the square root button on the TI-30XIIS and how do I solve, what is the square root of 62
Square root is the 2nd function of the square key, to the left of the 7 key. To compute the square root of 62, press 2nd [square-root] 6 2 ) =
2answers
Find missing number in this progression: 15 26 34 51 ? 84 96 125 [email protected]
The missing number is 61.
Look at perfect squares: (1,4,9),16, 25, 36, 49,64, 81,100,121
Then look at the given progression 15, 26, 34, 51, x, 84, 96,125
Take differences from the closest -1,+1, -2, +2, -3, +3, -4, +4
(15 is 1 less than 16 = 4 squared,
26 is 1 more than 25 = 5 squared,
34 is 2 less than 36 = 6 squared,
51 is 2 more than 49 = 7 squared,
61 is 3 less than 64 = 8 squared,
84 is 3 more than 81 = 9 squared,
96 is 4 less than 100 = 10 squared,
125 is 4 more than 121 = 11 squared)
3helpful
I need help with square root functions
The square root has a dedicated key sequence [2nd][V square root symbol]
Square root of 21.2846 is entered [2nd][V square root] 21.2846 [ENTER] .
The result is`4.614.
I suspect you want to calculate the 4th root of 21.2846. If it is the case you enter that as
21.2846 [^](1/4) =2.148
Square root can be also entered as [^](1/2)
Cube root is entered as [^] (1/3)
nth root is entered as [^](1/n)
Hope it helps.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
